Discuss
Dryer stopped working completely
 in
Dryer Repair
The Dryer will not start at all. I've checked the fuse at the mains and this is ok Help
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer stopped working completely
  #1 (permalink)
Old 10-24-2009, 06:29 AM
pns pns is offline
Junior Member
pns is on a distinguished road
Default Dryer stopped working completely
Model Number: ADE9005AGW   Brand: Admiral   Age: 1 - 5 years
Help please, thanks
Related Models
Admiral ADE9005AGW Dryer - Ele
Whirlpool ADF07520
Whirlpool ADF07521
Whirlpool ADF07522
Whirlpool ADF10020
Whirlpool ADF10220
Whirlpool ADF11021
Whirlpool ADF12020
Whirlpool ADF12540
Whirlpool ADF13520
Whirlpool ADF13521
Whirlpool ADF13522
Whirlpool ADF13523
Whirlpool ADF17040
Whirlpool ADF18040
Whirlpool ADF18041
Whirlpool ADF18043
Whirlpool ADF18044
Whirlpool ADF18240
Whirlpool ADF21240
Whirlpool ADF21340
Whirlpool ADF21342
Whirlpool ADF21343
Whirlpool ADF29040
Whirlpool ADF29041
Whirlpool ADF29042
Whirlpool ADF29043
Whirlpool ADFC6320
Whirlpool ADFC6321
Whirlpool ADFC6322
Whirlpool ADFE1240
Whirlpool ADFE1241
Whirlpool ADFE1242
Whirlpool ADFE1540
Whirlpool ADFE1541
Whirlpool ADFE1542
Whirlpool ADFE1830
Whirlpool ADFE1831
Whirlpool ADFH0720
Whirlpool ADFH0721
Whirlpool ADFH2130
Whirlpool ADFP5020
Whirlpool ADFP5021
Whirlpool ADFP5022
Whirlpool ADFP5023
Whirlpool ADFP5520
Whirlpool ADFP6021
Whirlpool ADFP6022
Whirlpool ADFP8020
Whirlpool ADFP8021
Whirlpool ADFR1240
Whirlpool ADFS1020
Whirlpool ADFS1021
Whirlpool ADFS6020
Whirlpool ADFS6021
Whirlpool ADFS8020
Whirlpool ADFS8021
Whirlpool ADFS8022
Whirlpool ADFW0940
Whirlpool ADFW0941
Whirlpool ADFW0942
Whirlpool ADFW1240
Whirlpool ADFW1241
Whirlpool ADFW1242
Whirlpool ADFW1540
Whirlpool ADFW1541
Whirlpool ADFW1542
Whirlpool ADFW1543
Whirlpool ADFW1544
Maytag ADG107 Dryer - Gas
Admiral ADG20K2A Dryer - Gas
Admiral ADG20K2H Dryer - Gas
Admiral ADG20K2W Dryer - Gas
Admiral ADG20K3 Dryer - Gas
Admiral ADG20K3A Dryer - Gas
Admiral ADG20K3H Dryer - Gas
Admiral ADG20K3V Dryer - Gas
Admiral ADG20K3W Dryer - Gas
Admiral ADG20K4 Dryer - Gas
Admiral ADG20K4A Dryer - Gas
Admiral ADG20K4H Dryer - Gas
Admiral ADG20K4W Dryer - Gas
Admiral ADG20L1A Dryer - Gas
Admiral ADG20L1H Dryer - Gas
Admiral ADG20L1W Dryer - Gas
Admiral ADG20L2A Dryer - Gas
Admiral ADG20L2H Dryer - Gas
Admiral ADG20L2W Dryer - Gas
Admiral ADG20L4 Dryer - Gas
Admiral ADG20L4A Dryer - Gas
Admiral ADG20L4H Dryer - Gas
Admiral ADG20L4W Dryer - Gas
Admiral ADG20M3V Dryer - Gas
Admiral ADG20N3V Dryer - Gas
Maytag ADG308 Dryer - Gas
Maytag ADG309 Dryer - Gas
Maytag ADG408 Dryer - Gas
Maytag ADG409 Dryer - Gas
Maytag ADG608 Dryer - Gas
Admiral ADG7000AWW Dryer - Gas
Admiral ADG7005AWW Dryer - Gas
Maytag ADG808 Dryer - Gas
Admiral ADG9000AWW Dryer - Gas
Amana ADGS902E Range - S/c S/i Ddraft Gas
Amana ADGS902SS Range - S/c S/i Ddraft Gas
Amana ADGS902WW Range - S/c S/i Ddraft Gas
General Electric ADH15D3Z1 Room air conditioner
General Electric ADH18D1G1 Room air conditioner
General Electric ADH18D1G2 Room air conditioner
General Electric ADH18D1G3 Room air conditioner
General Electric ADH18D3E1 Room air conditioner
General Electric ADH23D1X1 Room air conditioner
General Electric ADH23D3B1 Room air conditioner
Whirlpool ADJ06020
Whirlpool ADJ07220
Whirlpool ADJ07221
Whirlpool ADJ07520
Whirlpool ADJ07521
Whirlpool ADJ07522
Whirlpool ADJ10220
  #2 (permalink)
Old 10-24-2009, 07:43 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here are your parts includes a wiring diagram.
Replacement parts for ADMIRAL ADE9005AGW | AppliancePartsPros.com
If you just looked at the breaker try flipping it off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure it with a meter.
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral should both be 120 volts.
Next check the door switch to make sure it is being activated.
Better yet check it with a meter.
Next check the thermal fuse Item 6 in section 1 "Base" with a meter should be 0 ohms.
The jiggery pokery method is:
Unplug the unit.
Short the wires together
Tape them up so they cannot short to the frame.
Plug it in and try it.
If it runs replace the fuse ASAP as it is a critical safety device.
Note you can also use the same method for the door switch.
If the fuse is blown the most common cause is low air flow.
Clean the interior of the unit including the blower wheel.
Also clean and check your vent system.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven completely stopped working beatnikbean Oven Repair (including Ranges and Cooktops) 1 10-15-2009 01:43 PM
Dryer stopped working aich75013 Dryer Repair 1 03-11-2009 10:09 AM
Kenmore Ultra Wash - Completely stopped working, no lights gopogotom Dishwasher Repair 0 12-13-2008 09:41 AM
Gas dryer stopped working riverasol Dryer Repair 0 12-04-2008 09:45 PM
Admiral Dryer stopped working bobqhope Dryer Repair 0 04-28-2008 01:50 PM
