Whirlpool Dryer gets hot blows thermal fuse
Dryer Repair
My Whirlpool dryer wouldn't start. Replaced the thermal fuse and cleaned vents. Started a new load and about halfway through
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer gets hot blows thermal fuse
  #1 (permalink)
Old 07-06-2014, 01:27 PM
Junior Member
JanOlson is on a distinguished road
Default Whirlpool Dryer gets hot blows thermal fuse
Model Number: WED5300WV0   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool dryer wouldn't start. Replaced the thermal fuse and cleaned vents. Started a new load and about halfway through the thermal fuse blew again. Clothes were too hot to touch even on a low setting. Checked the coils and they seem ok. I assume its a thermostat but don't know which one. Any ideas?
Related Models
Whirlpool WED5310SQ0 29"ELECTRIC DRYER
Whirlpool WED5320SQ0 29"ELECTRIC DRYER
Whirlpool WED5321SQ0 29"ELECTRIC DRYER
Whirlpool WED5500SQ0 29"ELECTRIC DRYER
Whirlpool WED5500ST0 29"ELECTRIC DRYER
Whirlpool WED5500XL0 Electric Dryer
Whirlpool WED5500XW0 Electric Dryer
Whirlpool WED5510VQ0 29" ELECTRIC DRYER
Whirlpool WED5510VQ1 29"ELECTRIC DRYER
Whirlpool WED5520SQ0 29"ELECTRIC DRYER
Whirlpool WED5521SQ0 29"ELECTRIC DRYER
Whirlpool WED5530SQ0 29"ELECTRIC DRYER
Whirlpool WED5540SQ0 29"ELECTRIC DRYER
Whirlpool WED5540ST0 29"ELECTRIC DRYER
Whirlpool WED5550SQ0 29" ELECTRIC DRYER
Whirlpool WED5550ST0 29" ELECTRIC DRYER
Whirlpool WED5560SQ0 29" ELECTRIC DRYER
Whirlpool WED5590SQ0 29" ELECTRIC DRYER
Whirlpool WED5590VQ0 29" ELECTRIC DRYER
Whirlpool WED5590VQ1 29" ELECTRIC DRYER
Whirlpool WED5600SQ0 29" ELECTRIC DRYER
Whirlpool WED5600ST0 29" ELECTRIC DRYER
Whirlpool WED5600VQ0 29" ELECTRIC DRYER
Whirlpool WED5700SW0 29"ELECTRIC DRYER
Whirlpool WED5700VH0 29"ELECTRIC DRYER
Whirlpool WED5700VH1 29" ELECTRIC DRYER
Whirlpool WED5700VW0 29"ELECTRIC DRYER
Whirlpool WED5700VW1 29" ELECTRIC DRYER
Whirlpool WED5790SQ0 29" ELECTRIC DRYER
Whirlpool WED5790ST0 29" ELECTRIC DRYER
Whirlpool WED5790VQ0 29" ELECTRIC DRYER
Whirlpool WED5790VQ1 29" ELECTRIC DRYER
Whirlpool WED5800SG0 29"ELECTRIC DRYER
Whirlpool WED5800SW0 29"ELECTRIC DRYER
Whirlpool WED5810SW0 29"ELECTRIC DRYER
Whirlpool WED5820SW0 29"ELECTRIC DRYER
Whirlpool WED5821SW0 29"ELECTRIC DRYER
Whirlpool WED5830SW0 29"ELECTRIC DRYER
Whirlpool WED5840SG0 29"ELECTRIC DRYER
Whirlpool WED5840SW0 29"ELECTRIC DRYER
Whirlpool WED5850SG0 29"ELECTRIC DRYER
Whirlpool WED5850SW0 29"ELECTRIC DRYER
Whirlpool WED5860SG0 29"ELECTRIC DRYER
Whirlpool WED5860SW0 29"ELECTRIC DRYER
Whirlpool WED5900SB0 29" Electric Dryer
Whirlpool WED5900SW0 29" Electric Dryer
Whirlpool WED6200SW0 29"ELECTRIC DRYER
Whirlpool WED6200SW1 29"ELECTRIC DRYER
Whirlpool WED6400SB0 29"ELECTRIC DRYER
Whirlpool WED6400SB1 29" ELECTRIC DRYER
Whirlpool WED6400SG0 29"ELECTRIC DRYER
Whirlpool WED6400SG1 29" ELECTRIC DRYER
Whirlpool WED6400SW0 29"ELECTRIC DRYER
Whirlpool WED6400SW1 29" ELECTRIC DRYER
Whirlpool WED6600VU0 29" ELECTRIC DRYER
Whirlpool WED6600VW0 29" ELECTRIC DRYER
Whirlpool WED6600WL0 29"ELECTRIC DRYER
Whirlpool WED7300XW0 27" ELECTRIC DRYER
Whirlpool WED7400XW0 27"ELECTRIC DRYER
Whirlpool WED7600XW0 27" ELECTRIC DRYER
Whirlpool WED7800XB0 27" ELECTRIC DRYER
Whirlpool WED7800XL0 27" ELECTRIC DRYER
Whirlpool WED7800XW0 27" ELECTRIC DRYER
Whirlpool WED7990XG0 29" ELECTRIC DRYER
Whirlpool WED8200YW0 27" ELECTRIC DRYER
Whirlpool WED8300SB0 27" Electric Dryer
Whirlpool WED8300SB1 27" Electric Dryer
Whirlpool WED8300SB2 27" Electric Dryer
Whirlpool WED8300SE2 27" ELECTRIC DRYER
Whirlpool WED8300SW0 27" Electric Dryer
Whirlpool WED8300SW1 27" Electric Dryer
Whirlpool WED8300SW2 27" Electric Dryer
Whirlpool WED8410SW0 27"Electric Dryer
Whirlpool WED8410SW1 27" Electric Dryer
Whirlpool WED8410SW2 27" ELECTRIC DRYER
Whirlpool WED8500SR0 27"Electric Dryer
Whirlpool WED8600YW0 27" ELECTRIC DRYER
Whirlpool WED8800YC0 27" ELECTRIC DRYER
Whirlpool WED8800YW0 27" ELECTRIC DRYER
Whirlpool WED9050XW0 27" ELECTRIC DRYER
Whirlpool WED9050XW1 27" ELECTRIC DRYER
Whirlpool WED9150WW0 27" ELECTRIC DRYER
Whirlpool WED9150WW1 27" ELECTRIC DRYER
Whirlpool WED9151YW0 27" ELECTRIC DRYER
Whirlpool WED9250WL0 27" ELECTRIC DRYER
Whirlpool WED9250WL1 27" ELECTRIC DRYER
Whirlpool WED9250WR0 27" ELECTRIC DRYER
Whirlpool WED9250WR1 27" ELECTRIC DRYER
Whirlpool WED9250WW0 27" ELECTRIC DRYER
Whirlpool WED9250WW1 27" ELECTRIC DRYER
Whirlpool WED9270XL0 27" ELECTRIC DRYER
Whirlpool WED9270XL1 27" ELECTRIC DRYER
Whirlpool WED9270XL2 27" ELECTRIC DRYER
Whirlpool WED9270XR0 27" ELECTRIC DRYER
Whirlpool WED9270XR1 27" ELECTRIC DRYER
Whirlpool WED9270XR2 27" ELECTRIC DRYER
Whirlpool WED9270XW0 27" ELECTRIC DRYER
Whirlpool WED9270XW1 27" ELECTRIC DRYER
Whirlpool WED9270XW2 27" ELECTRIC DRYER
Whirlpool WED9371YL0 27" ELECTRIC DRYER
Whirlpool WED9371YW0 27" ELECTRIC DRYER
  #2 (permalink)
Old 07-07-2014, 03:43 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
I cannot find any info on the given model number.
Are you sure it is WV0 and not VW0?
The following is for a VW0 unit.
Here are the parts.
Parts for Whirlpool WED5300VW0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Is the air flow path in the unit including the blower wheel clean?
Make double sure that the vent system is clean and not kinked etc.
When you cleaned the vent system did you check that the louvers on the outside vent opened OK?
You have to check the heater with a meter.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
This can cause it to run on high.
The only thermostat that regulates the temperature if there is not a problem else where in the unit is the operating thermostat.
The others are safey devices and only have an effect it there is an over temperature problem.
  #3 (permalink)
Old 07-07-2014, 07:33 AM
Junior Member
You're right it is a VW0. Thanks for your help
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermal Fuse Blows caepperson3 Dryer Repair 0 07-05-2013 12:11 PM
Thermal fuse blows frequently gmay1 Dryer Repair 0 10-22-2011 09:42 PM
Kemore Dryer Thermal Fuse Blows brackman Dryer Repair 1 04-18-2011 07:20 AM
Thermal fuse repeatedly blows watchman Dryer Repair 1 09-04-2009 11:51 AM
dryer overheats, blows thermal fuse netsteeler Dryer Repair 7 06-03-2009 10:08 AM
