mrflv2bwl
#1 Posted : Sunday, July 6, 2014 9:48:45 AM(UTC)
mrflv2bwl
Recently my dryer would not start. I researched on line and came up with the solution that it would be wise to replace the high limit thermostat and the thermal fuse, so I bought that kit from you. Dryer not worked but the housing was extremely hot. Found venting almost clogged. So I replaced all the venting. Now the dryer works but clothes are extremely hot when cycle is down, even when I use the permanent press cycle. This never used to happen. Could the parts I purchased from you be defective? What's my next step?
#2 Posted : Sunday, July 6, 2014 10:59:20 AM(UTC)
[COLOR="Blue"]Could the parts I purchased from you be defective?[/COLOR]
No.
Both the parts you list are safety devices so have no effec t unless there is an over temperature problem.
Note that I do not work for AppliancePartsPros.
[COLOR="Blue"]What's my next step?[/COLOR]
Do you have the wiring diagram?
If not often it is stored in the control console of the unit.
Below is a link to a typical wiring diagram for this type of unit but I cannot say how close it matches your unit.
10-Wiring Information (series 15 Elec) parts for Admiral LNC7766B71 - AppliancePartsPros.com
Unplug the unit and put it close to the end of a permanent press cycle.
Now measure across the L to H contacts at the timer.
The contacts should be open, see the timing chart below the wiring diagram.
If not then the timer is bad.
Could also be a grounded element.
Unplug the unit and both wires at the heating element.
Measure across the element, should be about 12 ohms.
then measure from each side of the element to the case, both should be infinite ohms. If not then the element is grounded and should be replaced.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
