Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   GE HOT PoINT wiring DIaGram HELP! (http://forum.appliancepartspros.com/dryer-repair/553808-ge-hot-point-wiring-diagram-help.html)
SuperiorKATZ 07-03-2014 12:14 PM
My dad was replacing the timer on the GE hot point dryer and can not remember
which wire goes where. The tech sent us 6 wiring diagrams on the GE but none of them match the timer. I have attached a photo of the timer as well as the wiring on the dryer. He is not sure that what his has connected so far are even correct. Really need help my pop is 86 years old.
Don't know how to attach pictures.
Kathryn
fairbank56 07-03-2014 04:12 PM
Timer terminals:
A orange wire
B red wire
C white wire
D tan wire and tan jumper to terminal TD
E resistor to terminal W
W blue wire and resistor to terminal E
AD purple wire
TD tan wire and tan jumper to terminal D
Eric
SuperiorKATZ 07-03-2014 08:52 PM
GE HOT PoINT WIRING
Thank you so much Eric I will pass this on to my dad in the morning.
Kathryn
SuperiorKATZ 07-03-2014 08:53 PM
GE HOT PoINT WIRING
Thank you so much! I will pass this on to my dad in the morning.
Kathryn
SuperiorKATZ 07-04-2014 01:18 PM
GE HOT PoINT wiring
I just want to thank you again for your quick response and spot on instructions.
My parents have been washing and drying all day!
Thank you,
kathryn
SuperiorKATZ 07-04-2014 01:50 PM
Eric,
Spoke to soon - My dad just called on says timer is not working. is not advancing time. It is just running and not getting hot or cooling down.
Katheyn
fairbank56 07-05-2014 07:36 AM
I don't understand the "not getting hot or cooling down". If it doesn't get hot, how can it not cool down??? Anyway, why was the thermostat being replaced? What are the current symptoms in detail? Same as before thermostat was replaced or new symptoms?
Eric
