Discuss
Kenmore Gas Dryer will not heat
 in
Dryer Repair
Dryer will not dry. Vent and hose are clean. Flame comes on for about 4-6 seconds and then goes out.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Gas Dryer will not heat
  #1 (permalink)
Old 06-30-2014, 08:09 PM
Junior Member
K4CEB is on a distinguished road
Default Kenmore Gas Dryer will not heat
Model Number: 11092822101   Brand: Kenmore   Age: 5 - 10 years
Flame comes on for about 4-6 seconds and then goes out. After about 1-2 minutes it will go through the same process. Flame comes on and then goes out. Takes hours to dry anything. I have repaced the gas valves, igniter and flame sensor.
Got any ideas
Eric
Related Models
Kenmore 11092822101 GAS DRYER
Kenmore 11092822102 GAS DRYER
Kenmore 11092822103 RESIDENTIAL DRYER
Kenmore 11092824100 GAS DRYER
Kenmore 11092824101 GAS DRYER
Kenmore 11092824102 GAS DRYER
Kenmore 11092824103 RESIDENTIAL DRYER
Kenmore 11092826100 GAS DRYER
Kenmore 11092826101 GAS DRYER
Kenmore 11092826102 GAS DRYER
Kenmore 11092826103 RESIDENTIAL DRYER
Kenmore 11092832100 DRYER
Kenmore 11092834100 DRYER
Kenmore 11092836100 DRYER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094762300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094821300 GAS DRYER
Kenmore 11094821301 RESIDENTIAL DRYER
Kenmore 11094831300 GAS DRYER
Kenmore 11094831301 RESIDENTIAL DRYER
Kenmore 11094832200 GAS DRYER
Kenmore 11094832201 GAS DRYER
Kenmore 11094834200 GAS DRYER
Kenmore 11094834201 GAS DRYER
Kenmore 11094836200 GAS DRYER
Kenmore 11094836201 GAS DRYER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11094962300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094964300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094966300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094972300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094974300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094976300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11095081400 RESIDENTIAL DRYER
Kenmore 11095081401 DRYER
Kenmore 11095081402 RESIDENTIAL DRYER
Kenmore 11095087400 DRYER
Kenmore 11095087401 DRYER GAS
Kenmore 11095087402 RESIDENTIAL DRYER
Kenmore 11095088400 DRYER
Kenmore 11095088401 DRYER GAS
Kenmore 11095088402 RESIDENTIAL DRYER
Kenmore 11095089400 DRYER
Kenmore 11095089401 DRYER
Kenmore 11095089402 RESIDENTIAL DRYER
Kenmore 11095091400 RESIDENTIAL DRYER
Kenmore 11095091401 DRYER
Kenmore 11095091402 RESIDENTIAL DRYER
Kenmore 11095861400 RESIDENTIAL DRYER
Kenmore 11095861401 DRYER
Kenmore 11095862400 RESIDENTIAL DRYER
Kenmore 11095862401 DRYER
Kenmore 11095862402 RESIDENTIAL DRYER
Kenmore 11095866400 RESIDENTIAL DRYER
Kenmore 11095866401 DRYER
Kenmore 11095866402 RESIDENTIAL DRYER
Kenmore 11095871400 RESIDENTIAL DRYER
Kenmore 11095871401 DRYER
Kenmore 11095872400 RESIDENTIAL DRYER
Kenmore 11095872401 DRYER
Kenmore 11095872402 RESIDENTIAL DRYER
Kenmore 11095874400 RESIDENTIAL DRYER
Kenmore 11095874401 DRYER
Kenmore 11095874402 RESIDENTIAL DRYER
Kenmore 11095876400 RESIDENTIAL DRYER
Kenmore 11095876401 DRYER
Kenmore 11095876402 RESIDENTIAL DRYER
Kenmore 11096060100 ELECTRIC DRYER
Kenmore 11096091100 ELECTRIC DRYER
Kenmore 11096091300 ELECTRIC DRYER
Kenmore 11096091700 ELECTRIC DRYER
Kenmore 11096091800 ELECTRIC DRYER
Kenmore 11096093100 ELECTRIC DRYER
Kenmore 11096093300 ELECTRIC DRYER
Kenmore 11096093500 ELECTRIC DRYER
Kenmore 11096093700 ELECTRIC DRYER
Kenmore 11096093800 ELECTRIC DRYER
Kenmore 11096094100 ELECTRIC DRYER
Kenmore 11096094300 ELECTRIC DRYER
Kenmore 11096094500 ELECTRIC DRYER
Kenmore 11096094700 ELECTRIC DRYER
Kenmore 11096094800 ELECTRIC DRYER
Kenmore 11096110100 ELECTRIC DRYER
Kenmore 11096121100 ELECTRIC DRYER
Kenmore 11096195100 ELECTRIC DRYER
Kenmore 11096195110 DRYER FEATURE SHEET
Kenmore 11096195120 ELECTRIC DRYER
Kenmore 11096195500 ELECTRIC DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Dryer-No Heat EdgarC Dryer Repair 0 10-02-2011 04:09 PM
Kenmore dryer won't heat kypalak Dryer Repair 6 01-15-2011 06:04 PM
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off poslow Dryer Repair 2 11-21-2010 11:10 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 10:33 PM
Kenmore dryer will not heat lpennock Dryer Repair 2 05-11-2009 07:19 AM
