Discuss
Electical issue
 in
Dryer Repair
I bought a brand new dryer and electrical cord. My receptacle is a 3 prong plug 220. I plug in,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electical issue
  #1 (permalink)
Old 06-30-2014, 04:48 AM
Junior Member
jpwinkler001 is on a distinguished road
Default Electical issue
Brand: GE   Age: Less than 1 year
I bought a brand new dryer and electrical cord. My receptacle is a 3 prong plug 220. I plug in, I have power, I set the dryer to the settings I want, and when I hi the button to start the cycle the dryer shuts off. The breaker on the panel box does not trip when this happens and you can turn the dryer back on and do the same proces as above but the same thing happens. What is the problem?
  #2 (permalink)
Old 07-01-2014, 03:07 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Did you have to install the line cord?
If yes, did you follow the directions in the install sheet.
New dryers are usually set up for 4 wire hook up so a ground strap has to be added/connected for it to hook up to 3 wire.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Deforst issue / Ice Maker issue userkag Refrigerator & Freezer Repair 0 04-19-2011 09:20 AM
kitchen aid conv. oven c/w cooktop electical harness? robert oldham Oven Repair (including Ranges and Cooktops) 0 01-20-2011 10:52 AM
It had an electical problem which tripped out my breaker. It will n piruco Oven Repair (including Ranges and Cooktops) 1 07-13-2009 02:17 PM
It had an electical problem which tripped out my breaker. It will n piruco Oven Repair (including Ranges and Cooktops) 0 07-13-2009 09:09 AM
Garage Freezer - dead after burnt electical michaelphughes Refrigerator & Freezer Repair 4 06-27-2009 01:10 PM
