Discuss
Whirlpool Ultimate care 2 no heat
 in
Dryer Repair
Ok Hope to find some help here pulling my hair out with this one.... Got a washer and dryer pair
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Ultimate care 2 no heat
  #1 (permalink)
Old 06-27-2014, 06:02 PM
Junior Member
aemike09 is on a distinguished road
Default Whirlpool Ultimate care 2 no heat
Model Number: LGQ9858LW0   Brand: -brand-   Age: 5 - 10 years
Ok Hope to find some help here pulling my hair out with this one.... Got a washer and dryer pair from a friend that was sitting for a while because my washer went out and he wanted to get ride of them .... Long story short now i have a working washer but the dryer doesnt.... So being a automotive tech figured I would try and fix it myself and this is what I have come up with..... Checked all thermostats are ok ... went to ohm out ignitor and broke it so replaced it and still no flame but ignitor gets red hot glowing... So i then went and ohmed out the coils on top of the gas valves and the 2 terminal coil showed open i thought perfect i found the problem... Replaced both coils as they come as a set put dryer back together and still no flame.... It seems as if I can feel the valve click but no gas..... I also ohmed out the thermostat by the ignitor and it ohms out ok... Just not sure where to go with it from here thinking it must be the gas valve itself but would hate 2 spend the money and have it not fix it thanks for any help....
Related Models
Whirlpool LGQ9858LW0 RESIDENTIAL DRYER
Whirlpool LGQ9858LW1 29"GAS DRYER
Whirlpool LGQ9858PG0 29"GAS DRYER
Whirlpool LGQ9858PG1 29"GAS DRYER
Whirlpool LGQ9858PW0 29"GAS DRYER
Whirlpool LGQ9858PW1 29"GAS DRYER
Whirlpool LGR2614BW0 GAS DRYER
Whirlpool LGR2614BW1 GAS DRYER
Whirlpool LGR2614BW2 GAS DRYER
Whirlpool LGR2614DW0 GAS DRYER
Whirlpool LGR2614DW1 GAS DRYER
Whirlpool LGR2614EW0 GAS DRYER
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB RANGE- S/C F/S GAS
Admiral LGR3330ADW RANGE- S/C F/S GAS
Admiral LGR3330ADZ RANGE- S/C F/S GAS
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0 Residential Dryer
Whirlpool LGR3424AW0 Residential Dryer
Whirlpool LGR3622BN0 COMPACT GAS DRYER
Whirlpool LGR3622BW0 COMPACT GAS DRYER
Whirlpool LGR3622DQ1 COMPACT GAS DRYER
Whirlpool LGR3622DZ1 COMPACT GAS DRYER
Whirlpool LGR3624BN2 GAS DRYER
Whirlpool LGR3624BW0 GAS DRYER
Whirlpool LGR3624BW1 GAS DRYER
Whirlpool LGR3624BW2 GAS DRYER
Whirlpool LGR3624DQ1 GAS DRYER
Whirlpool LGR3624EQ0 GAS DRYER
Whirlpool LGR3624EQ1 GAS DRYER
Whirlpool LGR3624EQ2 GAS DRYER
Whirlpool LGR3624JQ0 GAS DRYER
Whirlpool LGR3624JQ1 RESIDENTIAL DRYER
Whirlpool LGR3624JQ2 29" GAS DRYER
Whirlpool LGR3624JQ3 29" GAS DRYER
Whirlpool LGR3624PQ0 29" GAS DRYER
Whirlpool LGR3624PQ1 29" GAS DRYER
Whirlpool LGR3634EW0 GAS DRYER
Whirlpool LGR3634EW1 GAS DRYER
Whirlpool LGR3634EW2 GAS DRYER
Whirlpool LGR3634EW3 GAS DRYER
Whirlpool LGR3634JW0 GAS DRYER
Whirlpool LGR3634JW1 RESIDENTIAL DRYER
Whirlpool LGR3634JW2 GAS DRYER
Admiral LGR3725ADC RANGE- S/C F/S GAS
Whirlpool LGR4434AN0 GAS DRYER
Whirlpool LGR4434AN1 GAS DRYER
Whirlpool LGR4434AQ0 Residential Dryer
Whirlpool LGR4434AQ1 GAS DRYER
Whirlpool LGR4434AW0 Residential Dryer
Whirlpool LGR4434AW1 GAS DRYER
Whirlpool LGR4436AW0 Residential Dryer
Whirlpool LGR4600PQ0 29" GAS DRYER
Whirlpool LGR4600PQ1 29" GAS DRYER
Whirlpool LGR4624BN0 GAS DRYER
Whirlpool LGR4624BN1 GAS DRYER
Whirlpool LGR4624BN2 GAS DRYER
Whirlpool LGR4624BQ0 GAS DRYER
Whirlpool LGR4624BQ1 GAS DRYER
Whirlpool LGR4624BQ2 GAS DRYER
Whirlpool LGR4624BW0 GAS DRYER
Whirlpool LGR4624BW1 GAS DRYER
Whirlpool LGR4624BW2 GAS DRYER
Whirlpool LGR4624DQ0 GAS DRYER
Whirlpool LGR4624DQ1 GAS DRYER
Whirlpool LGR4624DZ0 GAS DRYER
Whirlpool LGR4624DZ1 GAS DRYER
Whirlpool LGR4634BQ0 GAS DRYER
Whirlpool LGR4634BQ1 GAS DRYER
Whirlpool LGR4634BQ2 GAS DRYER
Whirlpool LGR4634DQ0 DRYERS
Whirlpool LGR4634DQ1 GAS DRYER
Whirlpool LGR4634DQO GAS DRYER
Whirlpool LGR4634DZ0 DRYERS
Whirlpool LGR4634DZO GAS DRYER
Whirlpool LGR4634EQ0 GAS DRYER
Whirlpool LGR4634EQ1 GAS DRYER
Whirlpool LGR4634EQ2 GAS DRYER
Whirlpool LGR4634EQ3 GAS DRYER
Whirlpool LGR4634EW0 GAS DRYER
Whirlpool LGR4634EZ0 GAS DRYER
Whirlpool LGR4634EZ1 GAS DRYER
Whirlpool LGR4634EZ2 GAS DRYER
Whirlpool LGR4634EZ3 GAS DRYER
Whirlpool LGR4634JQ0 GAS DRYER
Whirlpool LGR4634JQ1 GAS DRYER
Whirlpool LGR4634JQ2 GAS DRYER
Whirlpool LGR4634JQ3 29" GAS DRYER
Whirlpool LGR4634JT0 GAS DRYER
Whirlpool LGR4634JT1 GAS DRYER
Whirlpool LGR4634JT2 GAS DRYER
Whirlpool LGR4634JT3 29" GAS DRYER
Whirlpool LGR4634JZ0 GAS DRYER
Whirlpool LGR4634JZ1 GAS DRYER
Whirlpool LGR4634PQ0 29" GAS DRYER
Whirlpool LGR4634PQ1 29" GAS DRYER
Whirlpool LGR4634PT0 29" GAS DRYER
Whirlpool LGR4634PT1 29" GAS DRYER
Whirlpool LGR5434AW0 Residential Dryer
Whirlpool LGR5600HQ0 GAS DRYER
Whirlpool LGR5600HZ0 GAS DRYER
Whirlpool LGR5600JQ0 GAS DRYER
Whirlpool LGR5600JQ1 RESIDENTIAL DRYER
Whirlpool LGR5600JT0 GAS DRYER
Whirlpool LGR5600JT1 RESIDENTIAL DRYER
Whirlpool LGR5620KQ0 RESIDENTIAL DRYER
Whirlpool LGR5620KQ1 GAS DRYER
Whirlpool LGR5620KQ2 29"GAS DRYER
Whirlpool LGR5624BN0 GAS DRYER
Whirlpool LGR5624BN1 GAS DRYER
Whirlpool LGR5624BN2 GAS DRYER
Whirlpool LGR5624BW0 GAS DRYER
Whirlpool LGR5624BW1 GAS DRYER
Whirlpool LGR5624BW2 GAS DRYER
Whirlpool LGR5624DQ0 DRYERS
Whirlpool LGR5624DQ1 DRYER
Whirlpool LGR5624DW1 DRYER
Whirlpool LGR5624DZ0 DRYERS
Whirlpool LGR5624DZ1 DRYER
Whirlpool LGR5634AN0 GAS DRYER
  #2 (permalink)
Old 06-28-2014, 12:39 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
May be flame sensor stuck closed? (that's the device next to the ignitor). Does ignitor glow continuously? When ignitor gets glowing hot, flame sensor should open killing power to ignitor and allowing secondary gas valve to open. Ignitor will still be hot enough to ignite gas.
Eric
  #3 (permalink)
Old 06-28-2014, 03:57 PM
Junior Member
Default
Thanks for the reply the ignitor will get glowing hot and then will slowly go out seems about a 5 -10 sec till its not glowing at all ..... then if i leave the machine running in about another 30 sec or so the ignitor will start glowing again doing the same thing but never get any flame.... Is there any way i can test the gas valve should the rods that the coils sit on move in any way thanks...
  #4 (permalink)
Old 06-28-2014, 04:42 PM
Expert
APP Volunteer
Default
Flame sensor is working normally. The part that moves to open/close the valve is internal, you can't see it move. Where did you get the coils from? There's a lot of junk parts out there and Iv'e heard of many occasions where cheap coils simply did not work but everything worked fine when genuine Whirlpool FSP parts were used.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
Eric
  #5 (permalink)
Old 06-28-2014, 04:53 PM
Junior Member
Default
I got the coils form this site as a pair and replaced them as so ... Guess that is very possiable as that happens to me many times in the automotive field guess i may have to try another set they do ohm out ok but i know thats not always definitive....
  #6 (permalink)
Old 06-28-2014, 04:55 PM
Junior Member
Default
ohh and the ones i put in are from the same link you posted
  #7 (permalink)
Old 06-29-2014, 10:32 AM
Expert
APP Volunteer
Default
You should hear two clicks in the gas valves. The primary valve opens as soon as you turn the dryer on, the secondary opens after the ignitor gets hot enough to open the flame sensor. If they are both working, then looks like a faulty valve assembly or gas pressure problem.
Eric
  #8 (permalink)
Old 07-01-2014, 05:34 PM
Junior Member
Default
ok so i had a chance to mess with it for a little bit tonight and this is what I found... I checked voltage while running and while ignitor was being lite at the coils for the gas valve... At the 2 wire coil i got 120v at white wire constant and blue would go 120volts when ignitor would start to buzz on.... at the 3 wire coil white and blue go to 120volts with ignitor on and assuming black is some kinda ground does not really change much ..... so im assuming it must be a gas valve issue if those voltages sound right thanks for the help...
  #9 (permalink)
Old 07-02-2014, 05:55 AM
Expert
APP Volunteer
Default
Black wire is neutral. You should have one probe of your meter there for all measurements (or on a good ground). Both blue wires should be constant 120vac with dryer turned on. Both white wires should also be 120vac until heat from ignitor causes flame sensor to open. Voltage should drop significantly at that point.
Eric
  #10 (permalink)
Old 07-05-2014, 07:10 PM
Junior Member
Default
Figured i would update ended up ordering a gas valve which has fixed my problem and the dryer works properly now... Just my luck one time I decided to Fix the dryer and I get what seems to be a more uncommon problem for my case but i am very happy that it is fixed.... Thanks for all the help I Very much appriciate it...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool ultimate care II smith96 Washer Repair 7 05-28-2014 12:45 AM
whirlpool ultimate care ii. Blackgrass Washer Repair 1 01-18-2013 06:01 PM
Whirlpool Ultimate Care II fayef Washer Repair 3 10-29-2011 02:02 AM
whirlpool ultimate care 2 higleyml Washer Repair 4 07-05-2009 11:04 AM
Ultimate Care II - NO HEAT Qwintar Dryer Repair 0 03-02-2008 09:36 AM
