Discuss
Rumbling Noise for Maytag Dryer
 in
Dryer Repair
After 12 years, our dyer is showing signs of wear. Should I try to repair? It is making a lot
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Rumbling Noise for Maytag Dryer
  #1 (permalink)
Old 10-23-2009, 06:48 PM
Fixer2 Fixer2 is offline
Junior Member
Fixer2 is on a distinguished road
Default Rumbling Noise for Maytag Dryer
Model Number: LDE8704ACM   Brand: Maytag   Age: More than 10 years
It is making a lot of noise, both right when it starts up, but also while tumbling. I read somewhere (but now can not find again) posts that said the blower fan is likely the culprit. I am comfortable doing this repair, but fear there may be more. Since I will have the drum removed, I figured I should also replace the support rollers in the rear, too.
Do I need to replace the support roller shafts?
Belt and pully seem fine, but I am not sure what I shoud be looking for, either.
So far I am up to about $50 in parts - not sure if I would want to go much further, but what else would the experts recommend?
Thanks!!
Related Models
Maytag LDE8704ACM Dryer - Ele
Maytag LDE8706ACE Dryer - Ele
Maytag LDE8706ACM Dryer - Ele
Maytag LDE8706ADE Dryer - Ele
Whirlpool LDE8800W0
Whirlpool LDE8800W1
Maytag LDE8804ACE Dryer - Ele
Maytag LDE8804ACL Dryer - Ele
Maytag LDE8804ACM Dryer - Ele
Maytag LDE8804ADE Dryer - Ele
Maytag LDE882 Dryer - Ele
Maytag LDE8824ACE Dryer - Ele
Maytag LDE8824ACL Dryer - Ele
Maytag LDE8824ACM Dryer - Ele
Maytag LDE8824ADE Dryer - Ele
Maytag LDE882D Dryer - Ele
Maytag LDE8904ACE Dryer - Ele
Maytag LDE8904ACL Dryer - Ele
Maytag LDE8904ACM Dryer - Ele
Maytag LDE91 Dryer - Ele
Norge LDE912700 Dryer - Ele
Norge LDE912724 Dryer - Ele
Norge LDE9127A Dryer - Ele
Norge LDE9127H Dryer - Ele
Norge LDE9127S Dryer - Ele
Norge LDE9127W Dryer - Ele
Maytag LDE9206ACE Dryer - Ele
Maytag LDE9206ACM Dryer - Ele
Maytag LDE9206ADE Dryer - Ele
Maytag LDE9304ACE Dryer - Ele
Maytag LDE9304ACL Dryer - Ele
Maytag LDE9304ACM Dryer - Ele
Maytag LDE9304ADE Dryer - Ele
Maytag LDE9304ADL Dryer - Ele
Maytag LDE9304ADM Dryer - Ele
Maytag LDE9304AEE Dryer - Ele
Maytag LDE9306ACE Dryer - Ele
Maytag LDE9306ACM Dryer - Ele
Maytag LDE9306ADE Dryer - Ele
Maytag LDE9306ADM Dryer - Ele
Maytag LDE9306AEE Dryer - Ele
Maytag LDE9314ACE Dryer - Ele
Maytag LDE9314ACL Dryer - Ele
Maytag LDE9314ACM Dryer - Ele
Maytag LDE9314ADE Dryer - Ele
Maytag LDE9316ACE Dryer - Ele
Maytag LDE9316ACM Dryer - Ele
Maytag LDE9316ADE Dryer - Ele
Maytag LDE9334ACE Dryer - Ele
Maytag LDE9334ACL Dryer - Ele
Maytag LDE9334ACM Dryer - Ele
Maytag LDE9334ADE Dryer - Ele
Maytag LDE9606ACE Dryer - Ele
Maytag LDE9606ACM Dryer - Ele
Maytag LDE9606ADE Dryer - Ele
Maytag LDE9606ADM Dryer - Ele
Maytag LDE9606AEE Dryer - Ele
Maytag LDE9700 Dryer - Ele
Maytag LDE9700ACL Dryer - Ele
Maytag LDE9700ACW Dryer - Ele
Maytag LDE9700ADL Dryer - Ele
Maytag LDE9700ADW Dryer - Ele
Maytag LDE9701ACL Dryer - Ele
Maytag LDE9701ACW Dryer - Ele
Maytag LDE9701ADL Dryer - Ele
Maytag LDE9701ADW Dryer - Ele
Maytag LDE9800 Dryer - Ele
Maytag LDE9800ACL Dryer - Ele
Maytag LDE9800ACW Dryer - Ele
Maytag LDE9800ADL Dryer - Ele
Maytag LDE9800ADW Dryer - Ele
Whirlpool LDE9800W0
Whirlpool LDE9800W1
Whirlpool LDE9800W2
Maytag LDE9801ACL Dryer - Ele
Maytag LDE9801ACW Dryer - Ele
Maytag LDE9801ADL Dryer - Ele
Maytag LDE9801ADW Dryer - Ele
Maytag LDE9804ACE Dryer - Ele
Maytag LDE9804ACL Dryer - Ele
Maytag LDE9804ACM Dryer - Ele
Maytag LDE9804ADE Dryer - Ele
Maytag LDE9804ADL Dryer - Ele
Maytag LDE9804ADM Dryer - Ele
Maytag LDE9804AEE Dryer - Ele
Maytag LDE9804AEL Dryer - Ele
Maytag LDE9806ACE Dryer - Ele
Maytag LDE9806ACM Dryer - Ele
Maytag LDE9806ADE Dryer - Ele
International LDE9806GGE Dryer - Ele
Maytag LDE9814ACE Dryer - Ele
Maytag LDE9814ACL Dryer - Ele
Maytag LDE9814ACM Dryer - Ele
Maytag LDE9814ADE Dryer - Ele
Maytag LDE9824ACE Dryer - Ele
Maytag LDE9824ACL Dryer - Ele
Maytag LDE9824ACM Dryer - Ele
Maytag LDE9824ADE Dryer - Ele
Maytag LDE9900 Dryer - Ele
Maytag LDE9900ACL Dryer - Ele
Maytag LDE9900ACW Dryer - Ele
Maytag LDE9900ADL Dryer - Ele
Maytag LDE9900ADW Dryer - Ele
Maytag LDE9900BCL Dryer - Ele
Maytag LDE9900BCW Dryer - Ele
Maytag LDE9900BDL Dryer - Ele
Maytag LDE9900BDW Dryer - Ele
Maytag LDE9900R Dryer - Ele
Maytag LDE9904ACE Dryer - Ele
Maytag LDE9904ACL Dryer - Ele
Maytag LDE9904ACM Dryer - Ele
Maytag LDE9904ADE Dryer - Ele
Admiral LDEA100ACL Dryer - Ele
Admiral LDEA100ACW Dryer - Ele
Admiral LDEA100BCE Dryer - Ele
Admiral LDEA100BCM Dryer - Ele
Admiral LDEA200ACE Dryer - Ele
Admiral LDEA200ACL Dryer - Ele
Admiral LDEA200ACM Dryer - Ele
Admiral LDEA200ACW Dryer - Ele
  #2 (permalink)
Old 10-24-2009, 10:43 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
This is a very good dryer. Well worth a little TLC. No need to replace those rollers. You should oil them though. I use Zoomspout oil. It is a temp resistance non flammable, slow disapating HVAC oil used for a variety of applications from furnace blowers to you name it. $2 at any ace hardware store. On these dryers the most obvious thing is a loose blower wheel. This takes longer for the clothes to dry.
Maytag/Crosley/Admiral innards:
  #3 (permalink)
Old 10-24-2009, 12:32 PM
Junior Member
Default
Thanks JW. I should also mention it seems to make more noise on a heavy load. I have the parts on order now and will post back when repair is completed.
  #4 (permalink)
Old 10-28-2009, 10:47 AM
Junior Member
Default
Parts arrived in one day! Blower wheel was certainly stripped - had been wobbling and marred the sides of the chamber.
I will also replace the rollers as they seem thin and hardened - might as well since I have the dryer taken apart today.
Unfortunately, I didn't notice which way the wheel was on the roller spindle - does it matter? (One side seems to have a slightly different shape and has four posts...)
Also should I try to oil the motor itself, if so, where would I use my zoomspout??
Thanks!
  #5 (permalink)
Old 10-28-2009, 03:43 PM
Senior Expert
APP Volunteer
Default
The rollers go on either way; oil the rollers and the idler with your zoomspout, besure you clear out the lint from around the filter housing. I get any loose change you find!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Terrible noise when Maytag dryer is running goorock Dryer Repair 7 05-01-2009 04:53 AM
Maytag Dryer Noise chawkins@wvi.com Dryer Repair 3 03-07-2009 08:35 PM
Maytag dryer drum noise BillD Dryer Repair 3 06-23-2008 08:12 AM
Maytag dryer makes rumbling ...buttt... scotty8078 Dryer Repair 0 01-19-2008 03:03 PM
Dryer makes rumbling sound when starts Scottnvegas Dryer Repair 3 08-12-2007 09:00 PM
