I have a gas powered dryer only about 2 yrs old. It runs but does not produce heat. If you see the attached picture, it appears that there is scorching inside the drum from the vent left of the internal light. What would cause this? Is it worth repairing? Thanks, Kevin kevin koehler attached the following image(s):
