Discuss
Admiral Electric Dryer
 in
Dryer Repair
Last night I placed a loat in the old Admiral. Set the timer and walked away. Returned later to find
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Admiral Electric Dryer
  #1 (permalink)
Old 06-13-2014, 01:55 PM
Junior Member
BigRedOne is on a distinguished road
Default Admiral Electric Dryer
Brand: Admiral   Age: 5 - 10 years
Last night I placed a loat in the old Admiral. Set the timer and walked away. Returned later to find that the cloths were wet and the dryer had stopped. The timer knob was at the end of the full time. I reset the timer and pressed it in. The buzzer buzzed, then a POP! and the smell of burning wire. I unplugged the dryer. Just to be safe, and turned the rafters of my sun room into an old west laundry.
I haven't opened the back yet. So I'm not 100% sure it is the timer. However I had it open a month ago and blew everything out with the air compressor.
So my question is... Replace the timer or look for something else like the motor? Cash has been tight since my gal lost her job, so I would prefer things be cheep.
  #2 (permalink)
Old 06-14-2014, 03:32 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
Start at the rear access cover for the terminal strip perhaps the problem is there.
If all looks OK then open it up to find out what popped with luck you will be able to find it visually.
Even if you find a part that needs replacing I would check other things like the belt, idler wheel, front support glides, rear drum support rollers etc. for wear.
This should give you an idea of what is needed to overhaul the unit as it may niot be worth fixing.
__________________
  #3 (permalink)
Old 06-14-2014, 09:41 AM
Junior Member
Default Model Number
When I had it open for cleaning I checked the belt, and turn of the motor. The drum is well balanced so I don't think there is anything wrong there.
Model is Admiral ADE7000AYW
It says Heavy Duty / Super Capacity Plus / Quiet Pack / Dryer Rack on the front.
  #4 (permalink)
Old 06-14-2014, 10:40 AM
Senior Expert
APP Volunteer
Default
Here are your parts includes a wiring diagram
Parts for Admiral ADE7000AYW Dryer - AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Electric Dryer Austin3193 Dryer Repair 8 03-25-2011 08:39 AM
Admiral Electric Dryer lorigslater Dryer Repair 1 01-17-2011 04:15 AM
admiral electric dryer tripp67 Dryer Repair 4 12-27-2010 01:41 PM
Admiral Electric Dryer TJordan Dryer Repair 0 07-27-2010 05:52 PM
Admiral electric dryer won't run nhseacoast Dryer Repair 1 03-12-2010 12:38 AM
