Discuss
Maytag MDE7658BYW Timer not advancing/dryer will not shut off
 in
Dryer Repair
Hi, I have read several threads on this but I would like some personalized input prior to ordering replacement parts.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag MDE7658BYW Timer not advancing/dryer will not shut off
  #1 (permalink)
Old 06-13-2014, 11:47 AM
Junior Member
countrybois is on a distinguished road
Default Maytag MDE7658BYW Timer not advancing/dryer will not shut off
Model Number: MDE7658BYW   Brand: Maytag   Age: 5 - 10 years
My drier does not cycle the timer in any mode. It heats and dries fine, but doesn't cycle in either Accusensor mode or timed drying and therefore doesn't shut off. It also doesn't advance in air fluff and timed drying.
I've read several users who replace to timer to no avail. That seems the logical thing to replace. Others have said the dryness sensor board and that fixed it. Is there a way to determine which of these (if either) is bad or what is your recommendation. I do have a decent multimeter that I can check voltage if you give me some place to test.
The only other indicator I have is the moisture indicator cycles between damp and wet continually when a new load is put in. I'm not sure if it acted that way prior to the problem or not.
Thanks!
Related Models
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
Maytag MDE9706AZW DRYER- ELE
Maytag MDE9766AYW DRYER- ELE
Maytag MDE9766AZW DRYER- ELE
Maytag MDE9800AYQ DRYER- ELE
Maytag MDE9800AYW DRYER- ELE
Maytag MDE9800AZQ DRYER- ELE
Maytag MDE9800AZW DRYER- ELE
Maytag MDE9806AYA DRYER- ELE
Maytag MDE9806AYW DRYER- ELE
Maytag MDE9806AZW DRYER- ELE
Maytag MDE9876AYW DRYER- ELE
Maytag MDET236AYW DRYER- ELE
Maytag MDET236AZW DRYER- ELE
Maytag MDET336AYW DRYER- ELE
Maytag MDET336AZW DRYER- ELE
Maytag MDET446AYW DRYER- ELE
Maytag MDET446AZW DRYER- ELE
Maytag MDG100PN1 MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1L MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1W MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAGL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAKL MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDG10CSEGL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10MNAAW MANUAL, PARTS (DRYER GAS)
Admiral MDG10MNAGW DRYER- GAS
Maytag MDG10MNEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDEGL MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG10PDEGW MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG10PSABW MANUAL, PARTS (DRYER ELE)
Maytag MDG10PSAGL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDG10PSAGW MAYTAG LAUNDRY (DRYER ELE)
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
  #2 (permalink)
Old 06-14-2014, 03:24 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts includes a wiring diagram.
Parts for Maytag MDE7658BYW Dryer - AppliancePartsPros.com
One check you can do is to place the unit in timed dry.
Start the cycle and check for voltage (120 volts) across the timer motor.
If there is voltage and the timer does not advance then replace the timer.
If there is no voltage then I would replace the dryness board.
Be very very careful when doing this as there is 240 at the timer which is lethal!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gas Dryer Timer not Advancing = Clothes not Drying troxel Dryer Repair 5 03-11-2014 01:59 PM
Timer not advancing Maytag rross0311 Dryer Repair 0 11-10-2011 11:06 AM
Maytag timer not advancing in timed or auto. bigstik40 Dryer Repair 2 12-26-2010 01:00 PM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Maytag timer not advancing tealle Washer Repair 1 08-18-2009 05:27 PM
