Discuss
Help, Frigidaire Stackable Dryer won't heat, call repairman? or easy enough to DIY?
 in
Dryer Repair
Hey, need to decide if I need to call a repair man. My fleb8200ds0 Frigidaire Stackable Dryer won't heat. This
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Help, Frigidaire Stackable Dryer won't heat, call repairman? or easy enough to DIY?
  #1 (permalink)
Old 06-13-2014, 05:43 AM
Junior Member
latinojuan is on a distinguished road
Default Help, Frigidaire Stackable Dryer won't heat, call repairman? or easy enough to DIY?
Model Number: fleb8200ds0   Brand: Frigidaire   Age: 5 - 10 years
My fleb8200ds0 Frigidaire Stackable Dryer won't heat. This model is attached to the washer, I don't think it can detach. It turns and turns, but no heat. I've cleaned out the lint and opened it up and can't detect any places where lint might be, so I don't think that's the problem.
Can I use these steps?
Frigidaire Dryer Not Drying | eHow
"1
Make sure you aren't overloading your dryer. Try drying a load about half the size of your typical load and see if it dries. Often, problems arise when the dryer is too full.
2
Make sure the dryer is getting power. If your dryer won't even turn on, there is likely a problem with the power. Make sure the dryer is securely plugged into the electrical outlet. Check your breakers or fuses to make sure a breaker hasn't flipped or a fuse hasn't blown. Climb behind the dryer and use a screwdriver to remove the screws holding the plug access plate in place. Make sure the plug is properly attached to the dryer and wires are tightly fastened by the screws. Look for any signs of burning or wear on the plug itself. If you see signs of wear on the plug, replace it with a new one.
Sponsored Links
Maytag® Appliances
Shop for Maytag Appliances at the Home Depot Today!
maytag.homedepot.com
3
Clean out the lint tray and dryer vent. A clogged lint tray or dryer vent can decrease your Frigidaire's ability to effectively dry clothes. Remove the lint tray and clean out any lint. Move around to the back of the dryer and disconnect the dryer vent from the exhaust port on the dryer. Disconnect the other end from the exhaust port on the wall. Shake out any lint from the vent. Use a can of compressed air to blow the vent clean. Do the same for the exhaust port leading out of the house.
4
Disassemble your Frigidaire dryer to examine the other components. Slide a putty knife between the top panel and front panel, and slide it toward the center of the dryer to disconnect the retaining clips on the top panel. Lift the top panel up. Move the knife along the inside edges of the front panel, and lift the front panel up and off of the dryer. Disconnect the door switch wires and slide the front panel to the side. Disconnect the drum belt from the motor pulley, and raise the back end of the drum. Slide the drum forward and out of the dryer.
5
Replace the thermal fuse. The thermal fuse is a safety device designed to blow if your dryer gets too hot. It's located in the back right corner of the dryer, attached to heating element housing, and looks like a round piece of plastic with two wires coming out of the ends. Disconnect the wires and remove the screw holding the fuse in place. Screw a new fuse into place and reconnect the wires.
6
Replace the thermostat. The thermostat is a round piece of metal and plastic, located next to the thermal fuse. It regulates the temperature of your Frigidaire dryer. Disconnect the wires leading to the thermostat and remove the screws holding it in place. Screw a new thermostat in place and reconnect the wires.
7
Replace the heating element. The heating element is the internal component that actually generates heat within your dryer. Look at the element coils and see if any are broken. If none are broken, the element is fine. If one is, it must be replaced. Remove the thermal fuse and thermostat from the outside of the heating element housing. Disconnect the wires running to the heating element. Remove the screws holding the heating element and housing in place. Lift the housing out of the dryer. Install a new heating element and housing, and screw it into place. Reconnect the wires and reattach the thermal fuse and thermostat.
Read more: http://www.ehow.com/how_7278565_frigidaire-dryer-not-drying.html#ixzz34WRu0qJK"
I am not crazy about removing the drum, is it easy? I've found several youtube videos on how to remove the drum, doesn't seem too bad, but is it that different with my model? Can't seem to find the right one.
QUESTIONS:
1. should i just buy all three parts from here and replace them all? http://www.********************.com/...=118850&PID=19
2. is there anything that is very different from a normal dryer and drum removal versus my dryer/washer unit?
3. it also squeaks while turning... any idea what that might be?
THANKS!
Related Models
Frigidaire FLEB8200DS0 Frigidaire/laundry Center
Frigidaire FLEB8200FS0 Frigidaire/laundry Center
Frigidaire FLEB8200FS1 LAUNDRY CENTER
Frigidaire FLEB8200FS2 LAUNDRY CENTER
Frigidaire FLEB8200FS4 LAUNDRY CENTER
Frigidaire FLF316AQA Frigidaire/range
Frigidaire FLF316AQB Frigidaire/gas Range
Frigidaire FLF316ASA Frigidaire/range
Frigidaire FLF316ASB Frigidaire/gas Range
Frigidaire FLF316CQA Frigidaire/gas Range
Frigidaire FLF316CQB Frigidaire/gas Range
Frigidaire FLF316CQC Frigidaire/gas Range
Frigidaire FLF316CSA Frigidaire/gas Range
Frigidaire FLF316CSB Frigidaire/gas Range
Frigidaire FLF316CSC Frigidaire/gas Range
Frigidaire FLF316DQA Frigidaire/gas Range
Frigidaire FLF316DQB Frigidaire/gas Range
Frigidaire FLF316DQC Frigidaire/range
Frigidaire FLF316DQD Frigidaire/range
Frigidaire FLF316DQE GAS RANGE
Frigidaire FLF316DQF FRIGIDAIRE/RANGE
Frigidaire FLF316DSA Frigidaire/gas Range
Frigidaire FLF316DSB Frigidaire/gas Range
Frigidaire FLF316DSC Frigidaire/range
Frigidaire FLF316DSD Frigidaire/range
Frigidaire FLF316DSE GAS RANGE
Frigidaire FLF316DSF FRIGIDAIRE/RANGE
Frigidaire FLF316WHSA Frigidaire/gas Range
Frigidaire FLF316WHSB Frigidaire/gas Range
Frigidaire FLF316WHSC Frigidaire/gas Range
Frigidaire FLF316WHTA Frigidaire/gas Range
Frigidaire FLF316WHTB Frigidaire/gas Range
Frigidaire FLF316WHTC Frigidaire/gas Range
Frigidaire FLF326ASA Frigidaire/gas Range
Frigidaire FLF334BGDA Frg(v1) / Gas Range
Frigidaire FLF334BGDD Frg(v1) / Gas Range
Frigidaire FLF334BGDE Frg(v2) / Gas Range
Frigidaire FLF334BGDF Frigidaire/gas Range
Frigidaire FLF334BGDG Frigidaire/gas Range
Frigidaire FLF334BGDH Frigidaire/gas Range
Frigidaire FLF334BGWA Frg(v2) / Gas Range
Frigidaire FLF334BGWD Frg(v3) / Gas Range
Frigidaire FLF334BGWE Frg(v4) / Gas Range
Frigidaire FLF334BGWF Frigidaire/gas Range
Frigidaire FLF334BGWG Frigidaire/gas Range
Frigidaire FLF334BGWH Frigidaire/gas Range
Frigidaire FLF335CHSA Frigidaire/gas Range
Frigidaire FLF335CHSB Frigidaire/gas Range
Frigidaire FLF335CHSC Frigidaire/gas Range
Frigidaire FLF335CHTA Frigidaire/gas Range
Frigidaire FLF335CHTB Frigidaire/gas Range
Frigidaire FLF337AUA Frigidaire/gas Range
Frigidaire FLF337AUB Frigidaire/gas Range
Frigidaire FLF337AUC Frigidaire/gas Range
Frigidaire FLF337AUD Frigidaire/gas Range
Frigidaire FLF337AUE Frigidaire/gas Range
Frigidaire FLF337AUG Frigidaire/range
Frigidaire FLF337AUH Frigidaire/gas Range
Frigidaire FLF337AWA Frigidaire/gas Range
Frigidaire FLF337AWB Frigidaire/gas Range
Frigidaire FLF337AWC Frigidaire/gas Range
Frigidaire FLF337AWD Frigidaire/gas Range
Frigidaire FLF337AWE Frigidaire/gas Range
Frigidaire FLF337AWG Frigidaire/range
Frigidaire FLF337AWH Frigidaire/gas Range
Frigidaire FLF337ECC Frigidaire/range
Frigidaire FLF337ECD Frigidaire/range
Frigidaire FLF337ECE GAS RANGE
Frigidaire FLF337ECF GAS RANGE
Frigidaire FLF337ECG GAS RANGE
Frigidaire FLF337ECH GAS RANGE
Frigidaire FLF337ECJ GAS RANGE
Frigidaire FLF337ECK GAS RANGE
Frigidaire FLF337ECM GAS RANGE
Frigidaire FLF337ECN GAS RANGE
Frigidaire FLF337ECP GAS RANGE
Frigidaire FLF337ECR GAS RANGE
Frigidaire FLF337ECS GAS RANGE
Frigidaire FLF337EUC Frigidaire/range
Frigidaire FLF337EUD Frigidaire/range
Frigidaire FLF337EUE GAS RANGE
Frigidaire FLF337EUH GAS RANGE
Frigidaire FLF337EUJ GAS RANGE
Frigidaire FLF337EUK GAS RANGE
Frigidaire FLF337EUM GAS RANGE
Frigidaire FLF337EWC Frigidaire/range
Frigidaire FLF337EWD Frigidaire/range
Frigidaire FLF337EWE GAS RANGE
Frigidaire FLF337EWH GAS RANGE
Frigidaire FLF337EWJ GAS RANGE
Frigidaire FLF337EWK GAS RANGE
Frigidaire FLF337EWM GAS RANGE
Frigidaire FLF345HSA GAS RANGE
Frigidaire FLGB43RGS0
Frigidaire FLGB43RGS1 Laundry Center - Frig/best Buy
Frigidaire FLGB43RGS2 Lc - Frig/best Buy
Frigidaire FLGB43RGS3 Frigidaire/laundry Center
Frigidaire FLGB8200DS0 Frigidaire/laundry Center
Frigidaire FLGB8200DS1 Frigidaire/laundry Center
Frigidaire FLGB8200FS0 Frigidaire/laundry Center
Frigidaire FLGB8200FS1 LAUNDRY CENTER
Frigidaire FLGB8200FS2 LAUNDRY CENTER
Frigidaire FLGB8200FS3 LAUNDRY CENTER
Frigidaire FLGB8200FS5 LAUNDRY CENTER
Roper FLP310VW5 Range (gas)*
Whirlpool FLP310YG0
Whirlpool FLP310YL0
Roper FLP310YW0 Range (gas)*
Roper FLP320AL1 30" GAS FREESTANDING RANGE
Roper FLP320AW0 Range (gas)*
Roper FLP320AW1 30" GAS FREESTANDING RANGE
Roper FLP320VW0 Range (gas)*
Whirlpool FLP320YG0
Whirlpool FLP320YL0
Roper FLP320YW0 Range (gas)*
Roper FLP330VW0 Range (gas)*
Frigidaire FLS14B1D5 Wwh(v0) / Laundromat Commercial Front Loading Tumb
Frigidaire FLS26Z2GKB0 REFRIGERATOR
Frigidaire FLS26Z2GKB1 REFRIGERATOR
Frigidaire FLS26Z2GKB2 REFRIGERATOR
  #2 (permalink)
Old 06-14-2014, 03:14 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts includes a wiring diagram.
Parts for Frigidaire FLEB8200DS0 Washer Dryer Combo - AppliancePartsPros.com
Below is a link to a service manual.
I think it includes info on your unit.
You will have to join the site and be logged in to be able to download the manual.
http://appliancejunk.com/forums/inde...=view;down=427
The items you list 1 to 7 seem to all use the plug and chug method for appliance repair. definitely not the way to troubleshoot a problem. Also it can cost you a small fortune in parts.
I cannot say if you should get in a service tech as it depends on how handy you are and what tools/knowledge you have.
I would not as you could replace all three and still have the problem.
It is basically the same. as other units which use a rear center drum bearing for the drum support.
Usually this is the rear drum support bearing (item 32 in section 03).
Usually it just needs cleaning and re-greasing but sometimes it has to be replaced as it may be worn. Be sure to use a high temperature grease on it.
Also when removing the drum be careful with the little ball bearing (item 5 in section 03). It likes to jump out and then play hide and seek.
Note the squeaks may also be other things like the motor, the idler, the front glides etc.
Now for your problem.
First you have to check that the unit is getting the correct voltage.
The motor and timer run off of half the line but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If the voltage is OK then unplug the unit.
Check the heater with a meter. It should be around 12 ohms.
Check the hi-limit thermostat (item 33 in section 03), it should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire LC-3 Stackable Washer/Dryer justjeffb Washer Repair 0 04-18-2013 10:40 AM
Stackable frigidaire wash/dryer SiCkSTi04 Washer Repair 1 09-10-2012 05:05 PM
Gibson Call repair man or get rid of...stackable dryer temp isn't right and squeaks llccmama Dryer Repair 0 01-11-2011 08:53 PM
frigidaire stackable washer and dryer afeuquay001 Washer Repair 1 10-19-2009 10:34 AM
dryer does not heat after my Repairman freddiknox Dryer Repair 0 03-02-2009 08:45 AM
