Discuss
Whirlpool shuts off after 2-3 minutes
 in
Dryer Repair
Whirlpool gas dryer. The dryer vent was clear to the outside. The dryer starts and begins the cycle just fine.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool shuts off after 2-3 minutes
  #1 (permalink)
Old 06-12-2014, 09:19 AM
Junior Member
thetravlor is on a distinguished road
Default Whirlpool shuts off after 2-3 minutes
Model Number: LG7681XSW3   Brand: Whirlpool   Age: More than 10 years
Whirlpool gas dryer. The dryer vent was clear to the outside. The dryer starts and begins the cycle just fine. I started it with vent unplugged and it will run about 2-3 minutes with on/off cycle working and the heat output OK. It shuts itself off and will restart fine again. Inside appears to not have any clogs either.
It is about 20 years old, is it done?
Related Models
Whirlpool LG7681XSW3 GAS DRYER
Whirlpool LG7686XPW0 Residential Dryer
Whirlpool LG7686XPW1 Residential Dryer
Whirlpool LG7701XWW0 Residential Dryer
Whirlpool LG7761XWW0 Residential Dryer
Whirlpool LG7801XKW1 Residential Dryer
Whirlpool LG7801XMW0 Residential Dryer
Whirlpool LG7801XMW1 Residential Dryer
Whirlpool LG7801XMW2 Residential Dryer
Whirlpool LG7801XPW0 Residential Dryer
Whirlpool LG7801XSN1 GAS DRYER
Whirlpool LG7801XSW0 Residential Dryer
Whirlpool LG7801XSW1 Residential Dryer
Whirlpool LG7801XSW2 Residential Dryer
Whirlpool LG7806XPW0 Residential Dryer
Whirlpool LG7811XPW0 Residential Dryer
Amana LG8101LB DRYER- GAS
Amana LG8101WB DRYER- GAS
Amana LG8109L2 WASHER-TOP LOADING
Amana LG8109W2 DRYER- GAS
Amana LG8111LB DRYER- GAS
Amana LG8111LM DRYER- GAS
Amana LG8111WB DRYER- GAS
Amana LG8111WM DRYER- GAS
Amana LG8121LM DRYER- GAS
Amana LG8121WM DRYER- GAS
Amana LG8153LB DRYER- GAS
Amana LG8153LM DRYER- GAS
Amana LG8153WB DRYER- GAS
Amana LG8153WM DRYER- GAS
Amana LG8163LM DRYER- GAS
Amana LG8163WM DRYER- GAS
Amana LG8209L2 WASHER-TOP LOADING
Amana LG8209L3 WASHER-TOP LOADING
Amana LG8209W2 DRYER- GAS
Amana LG8209W3 DRYER- GAS
Amana LG8219L2 DRYER- GAS
Amana LG8219W2 DRYER- GAS
Amana LG8269L2 WASHER-TOP LOADING
Amana LG8269W2 DRYER- GAS
Amana LG8319L2 DRYER- GAS
Amana LG8319W2 DRYER- GAS
Amana LG8329W DRYER- GAS
Amana LG8369L2 WASHER-TOP LOADING
Amana LG8369W2 DRYER- GAS
Amana LG8409L2 DRYER- GAS
Amana LG8409W DRYER- GAS
Amana LG8409W2 DRYER- GAS
Amana LG8459L2 DRYER- GAS
Amana LG8459W DRYER- GAS
Amana LG8459W2 DRYER- GAS
Amana LG8469L2 DRYER- GAS
Amana LG8469W2 DRYER- GAS
Amana LG8509W DRYER- GAS
Amana LG8519L2 DRYER- GAS
Amana LG8519W2 DRYER- GAS
Amana LG8569L2 DRYER- GAS
Amana LG8569W2 DRYER- GAS
Whirlpool LG8601XWW0 Residential Dryer
Amana LG8609L2 DRYER- GAS
Amana LG8609W DRYER- GAS
Amana LG8609W2 DRYER- GAS
Whirlpool LG8651XWW0 Residential Dryer
Whirlpool LG8861XWQ0 Residential Dryer
Amana LG9012 WASHER-TOP LOADING
Amana LG9012 DRYER- GAS
Whirlpool LG9101XTN1 GAS DRYER
Whirlpool LG9101XTW0 Residential Dryer
Whirlpool LG9101XTW1 GAS DRYER
Amana LG9109W DRYER- GAS
Whirlpool LG9201XWW0 Residential Dryer
Whirlpool LG9201XWW1 Residential Dryer
Amana LG9209L2 DRYER- GAS
Amana LG9209W DRYER- GAS
Amana LG9209W2 DRYER- GAS
Whirlpool LG9301XTW0 Residential Dryer
Whirlpool LG9301XTW1 Residential Dryer
Whirlpool LG9381XTW0 Residential Dryer
Whirlpool LG9481XWW0 Residential Dryer
Whirlpool LG9481XWW1 Residential Dryer
Whirlpool LG9501XTF0 GAS DRYER
Whirlpool LG9501XTG0 GAS DRYER
Whirlpool LG9501XTM0 GAS DRYER
Whirlpool LG9501XTN0 GAS DRYER
Whirlpool LG9501XTW0 Residential Dryer
Whirlpool LG9501XTW1 Residential Dryer
Whirlpool LG9521XTW0 Residential Dryer
Whirlpool LG9521XTW1 Residential Dryer
Whirlpool LG9681XWW0 Residential Dryer
Whirlpool LG9681XWW1 Residential Dryer
Whirlpool LG9701XSN0 GAS DRYER
Whirlpool LG9801XKW1 Residential Dryer
Whirlpool LG9801XMW0 Residential Dryer
Whirlpool LG9801XMW1 Residential Dryer
Whirlpool LG9801XMW2 Residential Dryer
Whirlpool LG9801XPW0 Residential Dryer
Whirlpool LG9801XPW1 Residential Dryer
Whirlpool LG9801XSW0 Residential Dryer
Whirlpool LG9806XPW0 Residential Dryer
Amana LGA10AW DRYER- GAS
Amana LGA20AW DRYER- GAS
Amana LGA30AL DRYER- GAS
Amana LGA30AW DRYER- GAS
Amana LGA50AL DRYER- GAS
Amana LGA50AW DRYER- GAS
Amana LGA60AL DRYER- GAS
Amana LGA60AW DRYER- GAS
Amana LGA80AL DRYER- GAS
Amana LGA80AW DRYER- GAS
Amana LGA90AL DRYER- GAS
Amana LGA90AW DRYER- GAS
General Electric LGB116BPA1AD Gas range
General Electric LGB116BPA1WH Gas range
General Electric LGB116BPA5WH Gas range
General Electric LGB116GPR1 Gas range
General Electric LGB116GPT1AD Gas range
General Electric LGB116GPT1WH Gas range
  #2 (permalink)
Old 06-12-2014, 09:33 AM
Junior Member
Default
After reading some other posts, I turned heat button all the way down. It ran over 5 minutes OK. I changed into the gentle cycle about one third way up the heat scale and it ran less than 2 minutes until kicking off.
Heat control switch???
  #3 (permalink)
Old 06-12-2014, 10:57 AM
Junior Member
Default
Ohms test on fuse and thermostat both OK
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
XLO Burner Shuts Off After Two Minutes johnmeyer Oven Repair (including Ranges and Cooktops) 9 03-08-2015 04:01 PM
Oven shuts off within ten minutes TMeck Oven Repair (including Ranges and Cooktops) 5 08-28-2012 10:31 AM
dryer shuts off after about 5 minutes sydnchase Dryer Repair 1 03-22-2012 12:38 PM
Only works for a few minutes, then shuts off. lfshadow Dryer Repair 0 02-23-2012 05:14 AM
Microwave shuts off after 2-3 minutes bclarkston Microwave Repair 0 10-29-2009 09:17 AM
