Discuss
drum sounds like it is rubbing (loud) as it runs
 in
Dryer Repair
We bought this from a neighbor who was moving but they said it worked fine. When we turn on the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » drum sounds like it is rubbing (loud) as it runs
  #1 (permalink)
Old 06-10-2014, 05:59 PM
Junior Member
rickimb67 is on a distinguished road
Default drum sounds like it is rubbing (loud) as it runs
Model Number: sde515dayw   Brand: Maytag   Age: 5 - 10 years
We bought this from a neighbor who was moving but they said it worked fine. When we turn on the dryer there is a loud rubbing sound as the drum spins.
Related Models
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
Amana SDI22W-AG REF - SXS/I&W
  #2 (permalink)
Old 06-10-2014, 06:01 PM
Junior Member
Default
Quote:
there is a loud rubbing sound when the drum is turning
  #3 (permalink)
Old 06-11-2014, 03:47 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag SDE515DAYW Dryer - AppliancePartsPros.com
Run your fingers along the inside of the drum seal at the front and back of the drum, to see if anything is between the drum and the frame. Bra wires are famous for this.
Be careful just in case the object is sharp.
If the above is OK then it could be a lot of things.
At the top of the list would be worn front drum support glides.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum Rubbing When I Spin It By Hand TONY ZINK Washer Repair 0 10-02-2011 03:36 PM
Kenmore Dryer top rubbing the drum PopeyeDad Dryer Repair 2 05-04-2011 02:33 PM
Crosley cde6000 drum rubbing Captainhook426 Dryer Repair 3 04-08-2011 01:48 PM
GE Dryer Drum Rubbing cbkenney Dryer Repair 1 09-22-2009 08:31 PM
sears front loader sounds like rubbing or bearing going out daryljosie Washer Repair 16 04-28-2009 04:28 PM
