Discuss
Burned black wire to heating element
 in
Dryer Repair
Replaced heating element in 29 year old dryer this January. Worked fine until this week when no heat was entering
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Burned black wire to heating element
  #1 (permalink)
Old 06-09-2014, 03:54 PM
Junior Member
jkantczak is on a distinguished road
Default Burned black wire to heating element
Model Number: LDE412   Brand: Maytag   Age: More than 10 years
Replaced heating element in 29 year old dryer this January. Worked fine until this week when no heat was entering the dryer tub. Found burned wire. This situation is similar to others, but no good response or no definitive one. One Pro named Doug had good advise, but then advised that the element be replaced. I have a 4 month old element. Contact was tight, wire burned off the end piece. Okay to re use wire if I remove the damaged end? See photo.
Related Models
Maytag LDE412 DRYER- ELE
Maytag LDE482 DRYER- ELE
Maytag LDE490 DRYER- ELE
Maytag LDE4910 DRYER- ELE
Maytag LDE4910ACL DRYER- ELE
Maytag LDE4910ACW DRYER- ELE
Maytag LDE4914ACE DRYER- ELE
Maytag LDE4914ACL DRYER- ELE
Maytag LDE4914ACM DRYER- ELE
Maytag LDE4916ACE DRYER- ELE
Maytag LDE4916ACM DRYER- ELE
Maytag LDE4916ADE DRYER- ELE
Maytag LDE5004ACW DRYER- ELE
Maytag LDE5004ADW DRYER- ELE
Maytag LDE5005ACE DRYER- ELE
Maytag LDE5005ADE DRYER- ELE
Maytag LDE510 DRYER- ELE
Maytag LDE512 DRYER- ELE
Maytag LDE590 DRYER- ELE
Maytag LDE590D DRYER- ELE
Maytag LDE5910 DRYER- ELE
Maytag LDE5910ACL DRYER- ELE
Maytag LDE5910ACW DRYER- ELE
Maytag LDE5914ACE DRYER- ELE
Maytag LDE5914ACL DRYER- ELE
Maytag LDE5914ACM DRYER- ELE
Maytag LDE5916ACE DRYER- ELE
Maytag LDE5916ACM DRYER- ELE
Maytag LDE5916ADE DRYER- ELE
Maytag LDE6004ACW DRYER- ELE
Maytag LDE610 DRYER- ELE
Maytag LDE612 DRYER- ELE
Maytag LDE6914ACE DRYER- ELE
Maytag LDE6914ACL DRYER- ELE
Maytag LDE6914ACM DRYER- ELE
Maytag LDE710 DRYER- ELE
Maytag LDE712 DRYER- ELE
Maytag LDE713 DRYER- ELE
Maytag LDE7304ACE DRYER- ELE
Maytag LDE7304ACL DRYER- ELE
Maytag LDE7304ACM DRYER- ELE
Maytag LDE7304ADE DRYER- ELE
Maytag LDE7304ADL DRYER- ELE
Maytag LDE7304ADM DRYER- ELE
Maytag LDE7304AEE DRYER- ELE
Maytag LDE7304AGE DRYER- ELE
Maytag LDE7304AGL DRYER- ELE
Maytag LDE7304AGM DRYER- ELE
Maytag LDE7314ACE DRYER- ELE
Maytag LDE7314ACL DRYER- ELE
Maytag LDE7314ACM DRYER- ELE
Maytag LDE7314ADE DRYER- ELE
Maytag LDE7334ACE DRYER- ELE
Maytag LDE7334ACL DRYER- ELE
Maytag LDE7334ACM DRYER- ELE
Maytag LDE7400 DRYER- ELE
Maytag LDE7400ACL DRYER- ELE
Maytag LDE7400ACM DRYER- ELE
Maytag LDE7400ACW DRYER- ELE
Maytag LDE7400ADL DRYER- ELE
Maytag LDE7400ADW DRYER- ELE
Maytag LDE7480ACL DRYER- ELE
Maytag LDE7480ACW DRYER- ELE
Maytag LDE7480ADL DRYER- ELE
Maytag LDE7480ADW DRYER- ELE
Maytag LDE7500 DRYER- ELE
Maytag LDE7500ACE DRYER- ELE
Maytag LDE7500ACL DRYER- ELE
Maytag LDE7500ACM DRYER- ELE
Maytag LDE7500ACW DRYER- ELE
Maytag LDE7500ADE DRYER- ELE
Maytag LDE7500ADL DRYER- ELE
Maytag LDE7500ADM DRYER- ELE
Maytag LDE7500ADW DRYER- ELE
Maytag LDE7600 DRYER- ELE
Maytag LDE7600ACG DRYER- ELE
Maytag LDE7600ACL DRYER- ELE
Maytag LDE7600ACW DRYER- ELE
Maytag LDE7600ADL DRYER- ELE
Maytag LDE7600ADW DRYER- ELE
Maytag LDE7600AGG DRYER- ELE
Maytag LDE7600AGL DRYER- ELE
Maytag LDE7600AGW DRYER- ELE
Maytag LDE7800 DRYER- ELE
Maytag LDE7800ACL DRYER- ELE
Maytag LDE7800ACW DRYER- ELE
Maytag LDE7800ADL DRYER- ELE
Maytag LDE7800ADW DRYER- ELE
Maytag LDE8000 DRYER- ELE
Maytag LDE8000ACL DRYER- ELE
Maytag LDE8000ACW DRYER- ELE
Maytag LDE8000ADL DRYER- ELE
Maytag LDE8000ADW DRYER- ELE
Maytag LDE810 DRYER- ELE
Maytag LDE8200 DRYER- ELE
Maytag LDE8200ACE DRYER- ELE
Maytag LDE8200ACL DRYER- ELE
Maytag LDE8200ACW DRYER- ELE
Maytag LDE8200ADE DRYER- ELE
Maytag LDE8200ADL DRYER- ELE
Maytag LDE8200ADW DRYER- ELE
Maytag LDE8300 DRYER- ELE
Maytag LDE8300ACL DRYER- ELE
Maytag LDE8300ACW DRYER- ELE
Maytag LDE8304ACE DRYER- ELE
Maytag LDE8304ACL DRYER- ELE
Maytag LDE8304ACM DRYER- ELE
Maytag LDE8404ACE DRYER- ELE
Maytag LDE8404ACL DRYER- ELE
Maytag LDE8404ACM DRYER- ELE
Maytag LDE8404ADE DRYER- ELE
Maytag LDE8404ADL DRYER- ELE
Maytag LDE8404ADM DRYER- ELE
Maytag LDE8406ACE DRYER- ELE
Maytag LDE8406ACM DRYER- ELE
Maytag LDE8406ADE DRYER- ELE
Maytag LDE8410 DRYER- ELE
Maytag LDE8410ACE DRYER- ELE
Maytag LDE8410ACL DRYER- ELE
Maytag LDE8410ACW DRYER- ELE
  #2 (permalink)
Old 06-10-2014, 05:02 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag LDE412 Dryer - AppliancePartsPros.com
Unplug the unit and both wires from the element.
Measure across the element, should be around 8 to 12 ohms.
Then measure from each side of the element to the case, both should be infinite ohms.
If not the element is grounded and may have to be replaced.
If the element is OK then you can use the old wire but you have to cut it back until you have nice clean copper.
You will have to get a new high current connector and do a good crimp on it.
Also clean/check the connector at the element.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wire connecting heating element and high limit thermostat burned stubarnes4prez Dryer Repair 2 09-28-2013 07:29 AM
Burned wire - heating element issues MJQUEST1 Dryer Repair 2 06-04-2012 11:23 PM
Burned coil lower heating element, Maytag dejur95 Oven Repair (including Ranges and Cooktops) 0 03-04-2012 04:43 PM
Heating Element Wire Burned Off KenPaul Dishwasher Repair 2 05-24-2011 04:29 PM
Black wire to heating element keeps burning off ducky Dryer Repair 1 07-13-2009 02:17 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
