Discuss
Whirlpoor dryer turns when pressing start button, but stops immediately
 in
Dryer Repair
Howdy, our trusty Whirlpool dryer developed a new habit over the weekend where it will turn when pressing the start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpoor dryer turns when pressing start button, but stops immediately
  #1 (permalink)
Old 06-09-2014, 01:13 PM
Junior Member
stelip is on a distinguished road
Default Whirlpoor dryer turns when pressing start button, but stops immediately
Brand: Whirlpool   Age: 5 - 10 years
Howdy,
our trusty Whirlpool dryer developed a new habit over the weekend where it will turn when pressing the start button, but stop immediately when releasing the start button.
I checked the thermal fuse for continuity (it works), door switch (it works), and verified the drum is actually turning. Also ensured no lint in air passages/ducts, lint filter is clean as well.
Timer test as described in the tech sheet (which was taped into the control panel, I found it once I removed the rear cover) also checks out.
What could be broken/stuck/malfunctioning?
Any and all thoughts/insights much appreciated =)
Thx, S
  #2 (permalink)
Old 06-10-2014, 01:11 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
On most units there are two centrifugal switches on the motor that close when the motor gets close to operating speed.
One of them switches power onto the heating coil. This ensures that there is air flow before the heater comes on.
The other does two things.
It switches out the motor's start coil as if it is left on it will overheat the motor.
It also provides a parallel circuit path around the start switch which allows you to release the start switch and the unit keeps running.
Could be the motor is clogged with lint so the centrifugal mechanism on the motor is not working. If this is the case you will not have heat if you hold the start switch on.
Could be a bad switch or wire.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Matag Epic Z shuts off after pressing start button tspiers Washer Repair 21 11-04-2013 06:23 AM
Pressing start button has no effect tom luse Dryer Repair 1 07-22-2013 02:36 PM
Fuse trips after pressing START button Burde Kamath Microwave Repair 0 02-17-2013 08:55 AM
Dishwasher turns off immediately after pressing start DStanderfer Dishwasher Repair 0 11-18-2011 03:17 PM
Gas dryer won't start when pressing start button jimamy Dryer Repair 1 09-13-2010 02:28 PM
