Discuss
LG DRYER not rotating and cooling light is always on
 in
Dryer Repair
I have an LG TROMM DLE 2515S that was working fine other than the "cooling" light always being on. Now
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG DRYER not rotating and cooling light is always on
  #1 (permalink)
Old 06-09-2014, 07:41 AM
Junior Member
jjeff70 is on a distinguished road
Default LG DRYER not rotating and cooling light is always on
Model Number: DLE TROMM 2515S   Brand: -other-   Age: 5 - 10 years
I have an LG TROMM DLE 2515S that was working fine other than the "cooling" light always being on. Now it has decided not to rotate at all. I have power to the main board, meaning everything lights up and works as normal, but it will not rotate. I have replaced the moisture sensor bars and the door button (center front of dryer behind the door). I am thinking it is either the motor or the thermal fuse or maybe both and would like to get some advice before I invest in more parts (I've already replaced the drum and rollers). The parts I have found are 4681EL1008A for the motor and 6931EL3003D for the thermal fuse....any advice on troubleshooting further would be immensely appreciated!
Thanks,
Jody
Related Models
 DLE0332W Dryer
 DLE0442G Dryer
 DLE0442W Dryer
 DLE1310W Dryer
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer drum not rotating lilsqueaker10 Dryer Repair 1 05-02-2013 03:21 AM
LG Dryer runs but no heat; cooling light on grauchy Dryer Repair 0 03-30-2013 10:12 AM
Dryer squeals while rotating Mike Kane Dryer Repair 3 02-26-2012 08:14 AM
dryer drum not rotating correctly Firedog79 Dryer Repair 1 04-16-2010 09:18 AM
GE Electric Dryer Squeaking then not rotating kenro Dryer Repair 3 11-30-2009 01:32 AM
