Register | FAQ's | New Posts | Today's Posts | Extras |
» Dryer with no heat |
![]() Model Number: 110.600.72991 Brand: Kenmore Age: 1 - 5 years
![]() First time posting. My daughter has a Kemnore Elite Dryer that does not heat. The high temp cut-off switch keeps blowing. We have done the following; cleaned the entire exaust system, shortened the output hose to the outside to about 9 inches,replaced the heating element, replaced the thermal cut-off switch and thermostat(twice), and performed the troubleshoot tests that came with the dryer. Tests were ok. The dryer worked with a damp towel but when we put a small load of towels in, the cut-off switch blew again causing the heat to stop while the drum continued to operate. We have spent too much time and money on this problem. I am hoping that someone can lead us in the right direction and help us solve this problem. Thank you in advance. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Whirpool gas dryer won't heat already replace the coils and flame sensor and no heat | Joseph1976 | Dryer Repair | 0 | 05-30-2014 09:00 AM |
Dryer makes vibrations noises on heat but quite on no heat | Rmk600 | Dryer Repair | 0 | 03-07-2014 03:35 PM |
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
