Discuss
Crosley dryer is heating in all cycles.
 in
Dryer Repair
crosley dryer is overheating. heating element is fine. Heater stays on even in cool down or fluff cycles. Related Models
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Crosley dryer is heating in all cycles.
  #1 (permalink)
Old 06-05-2014, 09:35 AM
Junior Member
jackfaulkner is on a distinguished road
Default Crosley dryer is heating in all cycles.
Model Number: CEDS832VQ1   Brand: Crosley   Age: 1 - 5 years
Related Models
Whirlpool CEDS832VQ1 29" ELECTRIC DRYER
Crosley CEDS861 SURFACE UNIT- ELE
Whirlpool CEDS984RQ0 29"ELECTRIC DRYER
Whirlpool CEDS984RQ1 29"ELECTRIC DRYER
Crosley CEDW861 SURFACE UNIT- ELE
Whirlpool CEDX463JQ0 ELECTRIC DRYER
Whirlpool CEDX463JQ1 ELECTRIC DRYER
Whirlpool CEDX463MQ0 29"ELECTRIC DRYER
Whirlpool CEDX463MQ1 29"ELECTRIC DRYER
Whirlpool CEDX463RQ0 29"ELECTRIC DRYER
Whirlpool CEDX463RQ1 29"ELECTRIC DRYER
Whirlpool CEDX463RT0 29"ELECTRIC DRYER
Whirlpool CEDX463RT1 29"ELECTRIC DRYER
Whirlpool CEDX463SQ0 29"ELECTRIC DRYER
Whirlpool CEDX563JQ0 DRYER
Whirlpool CEDX563JQ1 DRYER
Whirlpool CEDX563JQ2 DRYER
Whirlpool CEDX631VQ1 29" ELECTRIC DRYER
Whirlpool CEE2760KQ0 DRYER
Whirlpool CEE2760KQ1 ELECTRIC DRYER
Whirlpool CEE2760KQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEE2790KQ0 DRYER
Whirlpool CEE2790KQ1 ELECTRIC DRYER
Whirlpool CEE2790KQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEE2990AG1 DRYER
Whirlpool CEE2990AG2 DRYER
Whirlpool CEE2990AG3 DRYER
Whirlpool CEE2990AN1 DRYER
Whirlpool CEE2990AN2 DRYER
Whirlpool CEE2990AN3 DRYER
Whirlpool CEE2990AW1 DRYER
Whirlpool CEE2990AW2 DRYER
Whirlpool CEE2990AW3 DRYER
Whirlpool CEE2990EW0 DRYER
Frigidaire CEE2M4WS5 Gib(v2) / Electric Range
Frigidaire CEE2M4WSAA Gib(v17) / Free Standing Electric Range
Frigidaire CEE2M4WSE Gib(v1) / Electric Range
Frigidaire CEE2M4WSPB Gib(v1) / Electric Range
Frigidaire CEE2M4WSPC Gib(v2) / Electric Range
Frigidaire CEE2M4WSPD Gib(v3) / Electric Range
Frigidaire CEF140CES0 Frigidaire/dryer
Thermador CEH30QB ELECTRIC COOKTOPS
Thermador CEH30QW ELECTRIC COOKTOPS
Frigidaire CEH343001 Frigidaire/electric Oven
Thermador CEH365QB
Thermador CEH365QW ELECTRIC COOKTOP
Thermador CEH365VQB
Thermador CEH365VQW ELECTRIC COOKTOPS
Thermador CEH456QB ELECTRIC COOKTOPS
Thermador CEH456QW ELECTRIC COOKTOPS
Crosley CEHA861 SURFACE UNIT- ELE
Crosley CEHW861 SURFACE UNIT- ELE
 CEI30EF5GBB RANGE
 CEI30EF5GSB RANGE
 CEI30EF5GSC RANGE
 CEI30EF5GSD RANGE
 CEI30EF5GSE RANGE
 CEI30EF5GSF RANGE
 CEI30EF5GSG RANGE
 CEI30EF5GWB RANGE
 CEI30GF5GSB GAS RANGE
 CEI30GF5GSC GAS RANGE
 CEI30GF5GSD GAS RANGE
 CEI30GF5GSE GAS RANGE
 CEI30GF5GSF GAS RANGE
 CEI30GF5GSG GAS RANGE
 CEI30GF5GSH GAS RANGE
Magic Chef CEL1110AAH RANGE- F/S STD ELE
Magic Chef CEL1110AAL RANGE- F/S STD ELE
Magic Chef CEL1110AAT RANGE- F/S STD ELE
Magic Chef CEL1115AAH RANGE- F/S STD ELE
Magic Chef CEL1115AAQ RANGE- F/S STD ELE
Magic Chef CEL1115AAW RANGE- F/S STD ELE
Crosley CELA861 SURFACE UNIT- ELE
Crosley CELS861 SURFACE UNIT- ELE
Crosley CELW861 SURFACE UNIT- ELE
Whirlpool CEM2750JQ0 COMMERCIAL DRYER
Whirlpool CEM2750KQ0 COMMERCIAL DRYER
Whirlpool CEM2750KQ1 DRYER
Whirlpool CEM2750KQ2 ELECTRIC DRYER
Whirlpool CEM2750KQ3 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2750TQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2750TQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760JQ0
Whirlpool CEM2760KQ0 COMMERCIAL DRYER
Whirlpool CEM2760KQ1 DRYER
Whirlpool CEM2760KQ2 COMMERCIAL DRYER
Whirlpool CEM2760KQ3 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760TQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760TQ1 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760TQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2940TQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2940TQ1 COMMERCIAL ELECTRIC DRYER
Thermador CEM304ZB
Thermador CEM304ZW
Thermador CEM365ZB
Thermador CEM365ZW
Thermador CEM456ZB
Thermador CEM456ZW
Hoover CEMP0504
Hoover CEMP1001
Hoover CEMP1004
Hoover CEMP1104
Hoover CEMP2004
Hoover CEMP3001
Hoover CEMP3004
Hoover CEMP3104
Whirlpool CEP2760KQ0 DRYER
Whirlpool CEP2760KQ1 COMMERCIAL DRYER
Whirlpool CEP2760KQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEP2960EW0 DRYERS
Whirlpool CEP2960JQ0 COMMERCIAL DRYER
Thermador CEP304ZB
Thermador CEP304ZW
Magic Chef CEP3540AAA RANGE- S/C D/I ELE
Magic Chef CEP3540AAQ RANGE- S/C D/I ELE
Magic Chef CEP3540AAW RANGE- S/C D/I ELE
Thermador CEP365ZB
Thermador CEP365ZW
Magic Chef CEP3760AAA RANGE- S/C D/I ELE
  #2 (permalink)
Old 06-06-2014, 03:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool CEDS832VQ1 Dryer - AppliancePartsPros.com
See the attachment for your wiring diagram.
Most likely a grounded element or a timer problem.
Unplug the unit and both wires at the heating element.
Measure across the heating element, should be 8 to 12 ohms.
Then measure from each side of the heating element to it's case, both should be infinite ohms.
If not then the element is grounded and should be replaced.
If the heater is OK.
Unplug the unit and set the timer to air only.
At the timer measure contacts B to A, it should be infinite ohms (open).
Also applies to C to A, see the timing chart.
__________________
  #3 (permalink)
Old 06-06-2014, 05:47 AM
Junior Member
Default
Both element and timer checked out good
  #4 (permalink)
Old 06-06-2014, 06:50 AM
Senior Expert
APP Volunteer
Default
Now I am stumped.
Did this unit ever run OK for you?
I can give you the circuit path for the heater element but am stumped as to why your heating element is always on.
L1 to C at the timer.
C to B at the timer.
B to A at the timer.
So if B to A (C to A) is open then the heater should not get any voltage.
A to the thermal cut-off, to the operating thermostat, to the hi-limit thermostat, to one side of the heating element.
Thru the heating element .
If the element is grounded it can get 120 volts on it (either L1 or L2 to ground/Neutral) and this then can by-pass the timer contacts and keep the element on.
To one side of the centrifugal switch then through the switch which closes when the motor is close to operating speed.
To L2.
This is then the circuit for the heating element which runs off of 240 volts.
Something weird is going on here!!!
Note that I am off to the cottage for the weekend and will not be available till Monday at the earliest.
__________________
  #5 (permalink)
Old 06-06-2014, 02:51 PM
Junior Member
Default
When the motor is not running, the timer turns the heat on and off at the appropriate places. However, when the motor is running, the heat stays on through all cycles. I thought it could be the switch on the motor...replaced the motor and it still does the same thing. One question I have...the element couldn't be bad if it is turning off and on by timer only..is that correct?
  #6 (permalink)
Old 06-06-2014, 03:46 PM
Junior Member
Default
Found the problem...when the heating element was out it checked fine, but the problem was when it was placed back into compartment, it was grounding out against back of dryer. I pushed the metal back in a bit to give more clearance and that solved the problem. Thank you for your help.
  #7 (permalink)
Old 06-10-2014, 02:13 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
crosley dryer tplumer Dryer Repair 1 11-23-2011 02:23 AM
gas cycles on and off while heating up navokitt1 Oven Repair (including Ranges and Cooktops) 0 10-10-2011 03:24 PM
Crosley Dryer cmbcoons@yahoo.com Dryer Repair 0 06-30-2011 09:55 PM
Need help with Crosley Dryer Now eagltrax Dryer Repair 0 09-28-2010 04:46 PM
Maytag dryer not heating up on all cycles and not properly drying clothes. radioman464 Dryer Repair 1 10-18-2007 04:48 AM
