Discuss
Maytag Neptune help!
 in
Dryer Repair
Hi, New to the forum. I picked up a used Neptune MDE6800AYW yesterday and it appeared to work fine at
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Neptune help!
  #1 (permalink)
Old 06-04-2014, 05:24 AM
Junior Member
jpcjguy is on a distinguished road
Default Maytag Neptune help!
Model Number: MDE6800AYW   Brand: Maytag   Age: More than 10 years
New to the forum. I picked up a used Neptune MDE6800AYW yesterday and it appeared to work fine at the guys house (1.5 hours away - was looking for the match). All I did for testing is hit some buttons and made sure it heated up. Loaded it up and brought it home.
Now it appears to work -functionally. I looked at diagnostic codes and saw an 08 - stuck key. Cleared it and figured it was an old code. Everything appeared fine. Did the sensor dry for a few minutes and then turned it off. About 5 minutes later it beeped on its own and it the panel was on again! What the?!? Did this several times. Plugged and unplugged a couple times. Same thing. I would hear 3 beeps in succession on occasion. Went into SC mode and tests appeared to work fine. It got progressively work (probably as I pressed the various buttons testing hundreds of times) The buttons are now responsive 90% of the time, but it just chirps intermittently like morse code - rapid fire beeps, sometimes on top of each other. It still appears to run fine, but when "off" (panel dark), it does that fast morse code thing. when I unplug the ribbon connector, it goes silent. Plug it in - chirps like a bird. I got my multimeter and jumped between the pins according to the chart for the settings keys - I had to use paperclips to get in the connector! All registered a "1" - which is open (touch the probes and it goes to "000").
I believe it is the panel, and would order one, but what if it not that?
Any help?
Thanks,
Joe
Related Models
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
Maytag MDE9706AZW DRYER- ELE
Maytag MDE9766AYW DRYER- ELE
Maytag MDE9766AZW DRYER- ELE
Maytag MDE9800AYQ DRYER- ELE
Maytag MDE9800AYW DRYER- ELE
Maytag MDE9800AZQ DRYER- ELE
Maytag MDE9800AZW DRYER- ELE
Maytag MDE9806AYA DRYER- ELE
Maytag MDE9806AYW DRYER- ELE
Maytag MDE9806AZW DRYER- ELE
Maytag MDE9876AYW DRYER- ELE
Maytag MDET236AYW DRYER- ELE
Maytag MDET236AZW DRYER- ELE
Maytag MDET336AYW DRYER- ELE
Maytag MDET336AZW DRYER- ELE
Maytag MDET446AYW DRYER- ELE
Maytag MDET446AZW DRYER- ELE
Maytag MDG100PN1 MANUAL, PARTS (DRYER GAS)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag neptune perry db Dryer Repair 0 10-26-2010 01:49 PM
maytag neptune tl rawhide 007 Washer Repair 3 10-25-2010 07:37 PM
Maytag Neptune imjrm Washer Repair 1 03-18-2009 04:52 PM
Maytag Neptune Sue Brown Washer Repair 0 07-05-2008 09:07 AM
maytag/neptune Bill Mahurin Washer Repair 3 06-18-2008 01:51 PM
