Register | FAQ's | New Posts | Today's Posts | Extras |
» whirlpool dryer not drying |
![]() Model Number: wed6200sw1 Brand: Whirlpool Age: 1 - 5 years
![]() My dryer will not dry anything , you can turn it on and timer counts down and everything ,but the drum does'nt turn and there is no heat. The last time that it did work it was very overheated. What should I do? Please help me. Thanks in advance..... Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Here are your parts
Parts for Whirlpool WED6200SW1 Dryer - AppliancePartsPros.com See the attachment for the tech sheet. Could be that the thermal fuse on the blower assembly blew. Could be that the thermal fuse on the blower wheel (Item 7 in Section 3) has blown. Unplug the unit and check the fuse with a meter should be 0 ohms. Jiggery Pokery method is. Unplug the unit. Remove both wires from the fuse, short them together and tape them up so they will not short to the frame. Plug the unit in and give it a try. If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires. Also clean/check your vent system and the blower as these are the most common causes of it blowing.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Whirlpool Dryer intermittant drying | rparker55 | Dryer Repair | 0 | 07-05-2012 09:33 PM |
Whirlpool Dryer not drying well | elya | Dryer Repair | 0 | 06-19-2011 09:00 PM |
whirlpool dryer not drying | slushdog69 | Dryer Repair | 3 | 06-15-2009 07:29 AM |
whirlpool dryer not drying | loq24 | Dryer Repair | 2 | 12-03-2008 05:10 AM |
Whirlpool Dryer not drying good | hmfary1 | Dryer Repair | 1 | 02-12-2008 07:58 PM |
