Discuss
Crosley Dryer taking to long to dry
 in
Dryer Repair
Ok, I have a Crosley Dryer that takes 3 or more times running on high heat to dry a regular
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Crosley Dryer taking to long to dry
  #1 (permalink)
Old 05-31-2014, 07:28 AM
Junior Member
Jerame82 is on a distinguished road
Default Crosley Dryer taking to long to dry
Model Number: CEDS832VQ1   Brand: Crosley   Age: 1 - 5 years
Ok, I have a Crosley Dryer that takes 3 or more times running on high heat to dry a regular sized load. I've checked the vent inside the unit, and the ducting leading out of the house, no blockage. I've checked the continuity on the High limit thermostat, the Heating Element, the Thermal Cut-off switch, the thermal fuse and the Cycling Thermostat, all of which have continuity..
Heating element (on 200Ohm setting) is 09.7... I'm getting 123v from each side of the plug (L1 to neutral, L2 to neutral), I'm getting the same at the terminal block.. what am i missing?
Also it takes the heating element quite a while to begin heating (i'd say approximently 30-40mins into the cycle)
Confused,
Jerame
Related Models
Whirlpool CEDS832VQ1 29" ELECTRIC DRYER
Crosley CEDS861 SURFACE UNIT- ELE
Whirlpool CEDS984RQ0 29"ELECTRIC DRYER
Whirlpool CEDS984RQ1 29"ELECTRIC DRYER
Crosley CEDW861 SURFACE UNIT- ELE
Whirlpool CEDX463JQ0 ELECTRIC DRYER
Whirlpool CEDX463JQ1 ELECTRIC DRYER
Whirlpool CEDX463MQ0 29"ELECTRIC DRYER
Whirlpool CEDX463MQ1 29"ELECTRIC DRYER
Whirlpool CEDX463RQ0 29"ELECTRIC DRYER
Whirlpool CEDX463RQ1 29"ELECTRIC DRYER
Whirlpool CEDX463RT0 29"ELECTRIC DRYER
Whirlpool CEDX463RT1 29"ELECTRIC DRYER
Whirlpool CEDX463SQ0 29"ELECTRIC DRYER
Whirlpool CEDX563JQ0 DRYER
Whirlpool CEDX563JQ1 DRYER
Whirlpool CEDX563JQ2 DRYER
Whirlpool CEDX631VQ1 29" ELECTRIC DRYER
Whirlpool CEE2760KQ0 DRYER
Whirlpool CEE2760KQ1 ELECTRIC DRYER
Whirlpool CEE2760KQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEE2790KQ0 DRYER
Whirlpool CEE2790KQ1 ELECTRIC DRYER
Whirlpool CEE2790KQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEE2990AG1 DRYER
Whirlpool CEE2990AG2 DRYER
Whirlpool CEE2990AG3 DRYER
Whirlpool CEE2990AN1 DRYER
Whirlpool CEE2990AN2 DRYER
Whirlpool CEE2990AN3 DRYER
Whirlpool CEE2990AW1 DRYER
Whirlpool CEE2990AW2 DRYER
Whirlpool CEE2990AW3 DRYER
Whirlpool CEE2990EW0 DRYER
Frigidaire CEE2M4WS5 Gib(v2) / Electric Range
Frigidaire CEE2M4WSAA Gib(v17) / Free Standing Electric Range
Frigidaire CEE2M4WSE Gib(v1) / Electric Range
Frigidaire CEE2M4WSPB Gib(v1) / Electric Range
Frigidaire CEE2M4WSPC Gib(v2) / Electric Range
Frigidaire CEE2M4WSPD Gib(v3) / Electric Range
Frigidaire CEF140CES0 Frigidaire/dryer
Thermador CEH30QB ELECTRIC COOKTOPS
Thermador CEH30QW ELECTRIC COOKTOPS
Frigidaire CEH343001 Frigidaire/electric Oven
Thermador CEH365QB
Thermador CEH365QW ELECTRIC COOKTOP
Thermador CEH365VQB
Thermador CEH365VQW ELECTRIC COOKTOPS
Thermador CEH456QB ELECTRIC COOKTOPS
Thermador CEH456QW ELECTRIC COOKTOPS
Crosley CEHA861 SURFACE UNIT- ELE
Crosley CEHW861 SURFACE UNIT- ELE
 CEI30EF5GBB RANGE
 CEI30EF5GSB RANGE
 CEI30EF5GSC RANGE
 CEI30EF5GSD RANGE
 CEI30EF5GSE RANGE
 CEI30EF5GSF RANGE
 CEI30EF5GSG RANGE
 CEI30EF5GWB RANGE
 CEI30GF5GSB GAS RANGE
 CEI30GF5GSC GAS RANGE
 CEI30GF5GSD GAS RANGE
 CEI30GF5GSE GAS RANGE
 CEI30GF5GSF GAS RANGE
 CEI30GF5GSG GAS RANGE
 CEI30GF5GSH GAS RANGE
Magic Chef CEL1110AAH RANGE- F/S STD ELE
Magic Chef CEL1110AAL RANGE- F/S STD ELE
Magic Chef CEL1110AAT RANGE- F/S STD ELE
Magic Chef CEL1115AAH RANGE- F/S STD ELE
Magic Chef CEL1115AAQ RANGE- F/S STD ELE
Magic Chef CEL1115AAW RANGE- F/S STD ELE
Crosley CELA861 SURFACE UNIT- ELE
Crosley CELS861 SURFACE UNIT- ELE
Crosley CELW861 SURFACE UNIT- ELE
Whirlpool CEM2750JQ0 COMMERCIAL DRYER
Whirlpool CEM2750KQ0 COMMERCIAL DRYER
Whirlpool CEM2750KQ1 DRYER
Whirlpool CEM2750KQ2 ELECTRIC DRYER
Whirlpool CEM2750KQ3 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2750TQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2750TQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760JQ0
Whirlpool CEM2760KQ0 COMMERCIAL DRYER
Whirlpool CEM2760KQ1 DRYER
Whirlpool CEM2760KQ2 COMMERCIAL DRYER
Whirlpool CEM2760KQ3 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760TQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760TQ1 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2760TQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2940TQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEM2940TQ1 COMMERCIAL ELECTRIC DRYER
Thermador CEM304ZB
Thermador CEM304ZW
Thermador CEM365ZB
Thermador CEM365ZW
Thermador CEM456ZB
Thermador CEM456ZW
Hoover CEMP0504
Hoover CEMP1001
Hoover CEMP1004
Hoover CEMP1104
Hoover CEMP2004
Hoover CEMP3001
Hoover CEMP3004
Hoover CEMP3104
Whirlpool CEP2760KQ0 DRYER
Whirlpool CEP2760KQ1 COMMERCIAL DRYER
Whirlpool CEP2760KQ2 COMMERCIAL ELECTRIC DRYER
Whirlpool CEP2960EW0 DRYERS
Whirlpool CEP2960JQ0 COMMERCIAL DRYER
Thermador CEP304ZB
Thermador CEP304ZW
Magic Chef CEP3540AAA RANGE- S/C D/I ELE
Magic Chef CEP3540AAQ RANGE- S/C D/I ELE
Magic Chef CEP3540AAW RANGE- S/C D/I ELE
Thermador CEP365ZB
Thermador CEP365ZW
Magic Chef CEP3760AAA RANGE- S/C D/I ELE
  #2 (permalink)
Old 05-31-2014, 02:58 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Do you have 240 volts from L1 to L2 at the unit's terminal strip.
Note that you can read 120 at L1 and L2 to Neutral and still have only half the line (120).
Your heating element resistance looks OK but did you check for a grounded element.
Unplug the unit and both wires at the heater,.
Measure across the heater, you should see your 9.3 ohms.
Then measure from each side of the heater to the case, both should be infinite ohms if not the heater is grounded and should be replaced.
__________________
  #3 (permalink)
Old 05-31-2014, 10:07 PM
Junior Member
Default
Ok I checked the terminal block and I'm getting 243v across L1 to L2.
I also checked the element and got infinate on both sides of the element so no grounded element
  #4 (permalink)
Old 06-01-2014, 04:44 AM
Senior Expert
APP Volunteer
Default
Parts for Whirlpool CEDS832VQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Just to be 100% sure that it is not a vent problem I would try the following.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
If the above makes no difference.
Unplug the unit and set the timer to high heat timed dry mid cycle.
Now measure from C on the timer to the centrifugal switch side of the heater.
You should get your 9.3 ohms.
Here we are trying to see if a thermostat or timer contact set has a resistance and is lowering the voltage to the heater.
If OK then I would replace the cycling thermostat on the bower assembly as that is the most likely cause.
If you have a fairly rapid response thermometer you could check your exhaust temperature.
On high heat the cycling thermostat should open at about 155 degrees F and then reclose at 130 degrees F.
__________________
  #5 (permalink)
Old 06-01-2014, 08:26 AM
Junior Member
Default
ok, I tested From C to the centrifugal switch side of the heater, and i didn't get any readings. So i had my wife slowly turn the timer knob through the entire cycle until i got a reading.. It wasn't until the timer was in the last 20 mins (cool down) portion of the cycle that i got the 9.7ohm reading. im i right to think its the timer i need to replace?
  #6 (permalink)
Old 06-01-2014, 09:32 AM
Senior Expert
APP Volunteer
Default
Yes that would also be my conclusion.
__________________
  #7 (permalink)
Old 06-01-2014, 10:35 AM
Junior Member
Default
Thank you so much for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer taking too long to dry Rockets33 Dryer Repair 1 01-25-2011 01:00 PM
Dryer taking too long to dry nahahn Dryer Repair 1 05-02-2010 11:09 AM
Dryer taking too long to dry rdpankratz Dryer Repair 1 11-05-2009 02:55 AM
Dryer taking long to dry delstvn Dryer Repair 1 08-28-2009 05:31 PM
dryer taking to long to dry pjjj5859 Dryer Repair 1 09-28-2007 01:54 AM
