Discuss
Maytag Dryer Buzzes and won't start
 in
Dryer Repair
Maytag ELECTRIC Dryer - Model LDE9800ACW - 22 Yrs old It Buzzes when the start button is pushed, but will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer Buzzes and won't start
  #1 (permalink)
Old 05-28-2014, 07:22 AM
Junior Member
LaneFowler is on a distinguished road
Angry Maytag Dryer Buzzes and won't start
Model Number: LDE9800ACW   Brand: Maytag   Age: More than 10 years
It Buzzes when the start button is pushed, but will not start. This is the same buzz signal it makes when a cycle is complete.
I was replacing the blower wheel and failed to unplug the unit. My fault! . Access is from the front by removing 2 screws at bottom of front panel and lifting up and out.
In order to get into the blower housing, you have to remove a metal shield that protects a series of wires/connectors on the front of the blower housing (Cycling thermostat???). When I removed the screws at the base that holds the metal sheild, gravity allowed it to move backwards and fall against the wires on the blower housing cover. This error produced mmediate sparks with the buzzing noise that normally occurs when the dryer is ready to shut-off. This went on for 20 seconds before I was able to get a wooden broom handle to knock the metal shield away from electrical contact. It was hot enough to produce a burn mark on the frame where it made contact.
The problem: Dryer is reassembled and dreum would seem to spin fine by hand. However, the dryer will not start when the start button is pushed. It buzzes, and that's it.
My thought is that I fried a Fuse, i.e., the thermal fuse? At the same time, the connectors/wires on the blower housing against which the shiled seemed to make contact do not include the theraml fuse?
Thoughts? Where is the termal fuse? On the Heating element tube accessed from the fron and not the back?
Related Models
Maytag LDE9800ACW DRYER- ELE
Maytag LDE9800ADL DRYER- ELE
Maytag LDE9800ADW DRYER- ELE
Maytag LDE9801ACL DRYER- ELE
Maytag LDE9801ACW DRYER- ELE
Maytag LDE9801ADL DRYER- ELE
Maytag LDE9801ADW DRYER- ELE
Maytag LDE9804ACE DRYER- ELE
Maytag LDE9804ACL DRYER- ELE
Maytag LDE9804ACM DRYER- ELE
Maytag LDE9804ADE DRYER- ELE
Maytag LDE9804ADL DRYER- ELE
Maytag LDE9804ADM DRYER- ELE
Maytag LDE9804AEE DRYER- ELE
Maytag LDE9806ACE DRYER- ELE
Maytag LDE9806ACM DRYER- ELE
Maytag LDE9806ADE DRYER- ELE
Admiral LDE9806GGE DRYER- ELE
Maytag LDE9814ACE DRYER- ELE
Maytag LDE9814ACL DRYER- ELE
Maytag LDE9814ACM DRYER- ELE
Maytag LDE9814ADE DRYER- ELE
Maytag LDE9824ACE DRYER- ELE
Maytag LDE9824ACL DRYER- ELE
Maytag LDE9824ACM DRYER- ELE
Maytag LDE9824ADE DRYER- ELE
Maytag LDE9900 DRYER- ELE
Maytag LDE9900ACL DRYER- ELE
Maytag LDE9900ACW DRYER- ELE
Maytag LDE9900ADL DRYER- ELE
Maytag LDE9900ADW DRYER- ELE
Maytag LDE9900BCL DRYER- ELE
Maytag LDE9900BCW DRYER- ELE
Maytag LDE9900BDL DRYER- ELE
Maytag LDE9900BDW DRYER- ELE
Maytag LDE9904ACE DRYER- ELE
Maytag LDE9904ACL DRYER- ELE
Maytag LDE9904ACM DRYER- ELE
Maytag LDE9904ADE DRYER- ELE
Admiral LDEA100ACL DRYER- ELE
Admiral LDEA100ACW DRYER- ELE
Admiral LDEA100BCE DRYER- ELE
Admiral LDEA100BCM DRYER- ELE
Admiral LDEA200ACE DRYER- ELE
Admiral LDEA200ACL DRYER- ELE
Admiral LDEA200ACM DRYER- ELE
Admiral LDEA200ACW DRYER- ELE
Admiral LDEA300AGE DRYER- ELE
Admiral LDEA300AGL DRYER- ELE
Admiral LDEA300AGW DRYER- ELE
Admiral LDEA300AKE DRYER- ELE
Admiral LDEA400ACE DRYER- ELE
Admiral LDEA400ACL DRYER- ELE
Admiral LDEA400ACM DRYER- ELE
Admiral LDEA400ACW DRYER- ELE
Admiral LDEA500ACE DRYER- ELE
Admiral LDEA500ACL DRYER- ELE
Admiral LDEA500ACM DRYER- ELE
Admiral LDEA500ACW DRYER- ELE
Hoover LDEH200ACV DRYER- ELE
Hoover LDEH200AGV DRYER- ELE
Hoover LDEH200AKV DRYER- ELE
 LDF6810BB Dishwasher
 LDF6810ST Dishwasher
 LDF6810WW Dishwasher
 LDF6920BB Dishwasher
 LDF6920ST Dishwasher
 LDF6920WW Dishwasher
 LDF7810BB Dishwasher
 LDF7810ST Dishwasher
 LDF7810WW Dishwasher
 LDF7811BB Dishwasher
 LDF7811ST Dishwasher
 LDF7811WW Dishwasher
 LDF7932ST Dishwasher
 LDF8812ST Dishwasher
 LDF9810ST Dishwasher
 LDF9932ST Dishwasher
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
Maytag LDG212 DRYER- GAS
Maytag LDG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG22CS MANUAL, PARTS (DRYER GAS)
Maytag LDG22CT MANUAL, PARTS (DRYER GAS)
Maytag LDG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CS MANUAL, PARTS (DRYER GAS)
Maytag LDG26CT MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CA MANUAL, PARTS (DRYER GAS)
Maytag LDG27CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG27CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG303 DRYER- GAS
Maytag LDG30CMD MANUAL, PARTS (DRYER GAS)
Maytag LDG312 DRYER- GAS
Maytag LDG313 DRYER- GAS
Maytag LDG31CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CT MAYTAG LAUNDRY (DRYER GAS)
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA MANUAL, PARTS (DRYER GAS)
Maytag LDG33CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CQ MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG382 DRYER- GAS
Maytag LDG4000 DRYER- GAS
  #2 (permalink)
Old 05-28-2014, 09:25 AM
Junior Member
Default Thermal fuse shorted/
The Metal Shield from previous post landed on Thermal Fuse - 306604 made a connection between this fuse and frame of unit.
Multimeter meter shows fluctuating resisitance on this thermal fuse (306604) versus zero resisitance on the other thermal fuse on this unit: Thermal Fuse - 307473
My thought is replace Thermal Fuse - 306604 and done?
Thoughts?
  #3 (permalink)
Old 05-28-2014, 11:01 AM
Junior Member
Unhappy Thermal Fuse By-Passed - Still No Good.
OK... I by-passed Thermal Fuse 306604 with a Jumper Wire. Still No Good. The Dryer just buzzes when thew Start Button is pushed.
Did I burn up the motor?
  #4 (permalink)
Old 05-29-2014, 07:07 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You may have blown out a timer contact when you shorted the thermal cutoff to ground. Unplug dryer. On back of timer, disconnect from terminal GY, the black wire that goes to timer motor. Unplug wire from BK terminal and connect to GY terminal. Plug dryer back in and see if motor will start.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer buzzes and won't start Jay Dodds Dryer Repair 1 12-14-2011 12:51 PM
Gas dryer buzzes but won't start Tomdevaney Dryer Repair 0 06-16-2011 04:49 PM
Dryer won't start. Buzzes loudly when start pressed. Spoiler9112 Dryer Repair 1 09-09-2010 07:19 AM
Maytag Dryer buzzes, but will not start...... FDAR Dryer Repair 2 11-14-2009 02:41 AM
Dryer buzzes but won't start Tofudisan Dryer Repair 8 08-28-2009 07:15 PM
