Discuss
Dryer heats then no heat after 2-3 minutes.
 in
Dryer Repair
My Brother-In-Law had a repair guy over, since the guy was at the neighbors house. His dryer wasn't heating, the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heats then no heat after 2-3 minutes.
  #1 (permalink)
Old 05-21-2014, 07:31 PM
Junior Member
007kevin is on a distinguished road
Default Dryer heats then no heat after 2-3 minutes.
Model Number: Base Model   Brand: Whirlpool   Age: Less than 1 year
My Brother-In-Law had a repair guy over, since the guy was at the neighbors house. His dryer wasn't heating, the guy tested some thing and told him to order the cycle/timer switch, he replaced it, and said it worked for about 3-4 minutes and then no heat. So I went to his house check every component for the electrical system, including all relays, swtiches and, coil, etc. etc. Along with all the resistors, high limit, thermostat, etc. etc. They all checked out fine on my ohm meter. Here is the thing, if you let it sit for about 10-15 minutes it will light and run for about 2-3 minutes or so, then go out again. Checked all vents and they seem clean and not restricted. Any help would be great, thanks all
Kevin
Related Models
Amana BB20V1E REF - BOTTOM MOUNTS
Amana BB20V1PS REF - BOTTOM MOUNTS
Amana BB20V1S REF - BOTTOM MOUNTS
Amana BB20V1W REF - BOTTOM MOUNTS
Amana BB20VE REF - BOTTOM MOUNTS
Amana BB20VPSE REF - BOTTOM MOUNTS
Amana BB20VSE REF - BOTTOM MOUNTS
Amana BB20VW REF - BOTTOM MOUNTS
Frigidaire BBBD2432KB0 DISHWASHER
Frigidaire BBBD2432KF0 DISHWASHER
Frigidaire BBBD2432KW0 DISHWASHER
Amana BBI20TE REF - BOTTOM MOUNTS
Amana BBI20TL REF - BOTTOM MOUNTS
Amana BBI20TPE REF - BOTTOM MOUNTS
Amana BBI20TPL REF - BOTTOM MOUNTS
Amana BBI20TPSW REF - BOTTOM MOUNTS
Amana BBI20TPW REF - BOTTOM MOUNTS
Amana BBI20TW REF - BOTTOM MOUNTS
Amana BC20B REF - BOTTOM MOUNTS
Amana BC20BA REF - BOTTOM MOUNTS
Amana BC20BC REF - BOTTOM MOUNTS
Amana BC20BG REF - BOTTOM MOUNTS
Amana BC20BL REF - BOTTOM MOUNTS
Amana BC20C REF - BOTTOM MOUNTS
Amana BC20CA REF - BOTTOM MOUNTS
Amana BC20CC REF - BOTTOM MOUNTS
Amana BC20CG REF - BOTTOM MOUNTS
Amana BC20CL REF - BOTTOM MOUNTS
Amana BC20D REF - BOTTOM MOUNTS
Amana BC20DA REF - BOTTOM MOUNTS
Amana BC20DC REF - BOTTOM MOUNTS
Amana BC20DG REF - BOTTOM MOUNTS
Amana BC20DL REF - BOTTOM MOUNTS
Amana BC20E REF - BOTTOM MOUNTS
Amana BC20EA REF - BOTTOM MOUNTS
Amana BC20EC REF - BOTTOM MOUNTS
Amana BC20EG REF - BOTTOM MOUNTS
Amana BC20EL REF - BOTTOM MOUNTS
Amana BC20H REF - BOTTOM MOUNTS
Amana BC20J REF - BOTTOM MOUNTS
Amana BC20K REF - BOTTOM MOUNTS
Amana BC20M REF - BOTTOM MOUNTS
Amana BC20N REF - BOTTOM MOUNTS
Amana BC20TL REF - BOTTOM MOUNTS
Amana BC20TW REF - BOTTOM MOUNTS
Amana BC20W REF - BOTTOM MOUNTS
Amana BC20WA REF - BOTTOM MOUNTS
Amana BC20WAG REF - BOTTOM MOUNTS
Amana BC20WC REF - BOTTOM MOUNTS
Amana BC21V1C REF - BOTTOM MOUNTS
Amana BC21V1W REF - BOTTOM MOUNTS
Amana BC21VC REF - BOTTOM MOUNTS
Amana BC21VL REF - BOTTOM MOUNTS
Amana BC21VW REF - BOTTOM MOUNTS
Frigidaire BCEQ2152ES0 Frigidaire Canada/electric Dryer
Frigidaire BCEQ2152ES1 FRIGIDAIRE
Frigidaire BCEQ6100FS0 Frigidaire/dryer
Frigidaire BCEQ6700FS0 FRIGIDAIRE/DRYER
Amana BCI20B REF - BOTTOM MOUNTS
Amana BCI20BA REF - BOTTOM MOUNTS
Amana BCI20BC REF - BOTTOM MOUNTS
Amana BCI20BG REF - BOTTOM MOUNTS
Amana BCI20BL REF - BOTTOM MOUNTS
Amana BCI20C REF - BOTTOM MOUNTS
Amana BCI20CA REF - BOTTOM MOUNTS
Amana BCI20CC REF - BOTTOM MOUNTS
Amana BCI20CG REF - BOTTOM MOUNTS
Amana BCI20CL REF - BOTTOM MOUNTS
Amana BCI20D REF - BOTTOM MOUNTS
Amana BCI20DA REF - BOTTOM MOUNTS
Amana BCI20DC REF - BOTTOM MOUNTS
Amana BCI20DG REF - BOTTOM MOUNTS
Amana BCI20DL REF - BOTTOM MOUNTS
Amana BCI20E REF - BOTTOM MOUNTS
Amana BCI20EA REF - BOTTOM MOUNTS
Amana BCI20EC REF - BOTTOM MOUNTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Heats for 5-10 minutes then heat shuts off mgutting Dryer Repair 0 11-09-2011 06:30 PM
Gas dryer heats 15 minutes on Automatic Dry Alta Lawn Care Dryer Repair 0 04-01-2010 07:08 PM
Gas dryer heats up for a couple minutes then no heat + gas smell keithk78 Dryer Repair 2 10-19-2009 09:29 PM
Dryer heats for a few minutes then no heat BLysek Dryer Repair 3 01-31-2009 06:55 AM
gas dryer heats for only a few minutes ElvisPresley Dryer Repair 4 11-20-2008 06:27 AM
