Discuss
Switch operates in reverse
 in
Dryer Repair
Hello, replaced the blower fan no problem, after reassemble noticed the door switch reversed, it starts when the door is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Switch operates in reverse
  #1 (permalink)
Old 05-12-2014, 12:47 PM
Junior Member
Spohr1 is on a distinguished road
Default Switch operates in reverse
Model Number: DGL203W   Brand: Norge   Age: More than 10 years
Hello, replaced the blower fan no problem, after reassemble noticed the door switch reversed, it starts when the door is open and shuts off when closed. Purchased a new switch from you and it still does the same thing what am I missing? thanks!
Related Models
Norge DGL203W DRYER- GAS
Norge DGL203WC DRYER- GAS
Norge DGM202A DRYER- GAS
Norge DGM202H DRYER- GAS
Norge DGM202W DRYER- GAS
Norge DGM204A DRYER- GAS
Norge DGM204H DRYER- GAS
Norge DGM204W DRYER- GAS
Norge DGM205A DRYER- GAS
Norge DGM205AC DRYER- GAS
Norge DGM205W DRYER- GAS
Norge DGM205WC DRYER- GAS
Frigidaire DGMV174KFA MICROWAVE
Frigidaire DGMV174KFB MICROWAVE
Norge DGN202A DRYER- GAS
Norge DGN202W DRYER- GAS
Norge DGN203A DRYER- GAS
Norge DGN203W DRYER- GAS
Norge DGN204A DRYER- GAS
Norge DGN204V DRYER- GAS
Norge DGN204W DRYER- GAS
Amana DGO-791 RANGE- S/C S/I DDRAFT GAS
Amana DGO-851 RANGE- S/C S/I DDRAFT GAS
Amana DGO757 SURFACE UNIT- GAS
Norge DGP223M DRYER- GAS
Norge DGP223V DRYER- GAS
Norge DGP224V DRYER- GAS
Dynasty DGR2484G RANGE - DBL OVEN STAINLESS ST
Dynasty DGR2484GCB RANGE - DBL OVEN STAINLESS ST
Dynasty DGR2486CB RANGE - DBL OVEN STAINLESS ST
Dynasty DGR2486G RANGE - DBL OVEN STAINLESS ST
Dynasty DGR2488 RANGE - DBL OVEN STAINLESS ST
Dynasty DGR304 RANGE - F/S GAS STAINLESS ST
Dynasty DGR364 RANGE - F/S GAS STAINLESS ST
Dynasty DGR364CB RANGE - F/S GAS STAINLESS ST
Dynasty DGR364G RANGE - F/S GAS STAINLESS ST
Dynasty DGR365WOK RANGE - F/S GAS STAINLESS ST
Dynasty DGR366 RANGE - F/S GAS STAINLESS ST
Dynasty DGR486G RANGE - F/S GAS STAINLESS ST
Dynasty DGR605GCBWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGR606G RANGE - F/S GAS STAINLESS ST
Dynasty DGR606GCB RANGE - F/S GAS STAINLESS ST
Dynasty DGR607CBWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGR607GWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGR608 RANGE - F/S GAS STAINLESS ST
Dynasty DGR609WOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRC2484G RANGE - DBL OVEN STAINLESS ST
Dynasty DGRC2485GWOK RANGE - DBL OVEN STAINLESS ST
Dynasty DGRC2486CB RANGE - DBL OVEN STAINLESS ST
Dynasty DGRC2486G RANGE - DBL OVEN STAINLESS ST
Dynasty DGRC364 RANGE - F/S GAS STAINLESS ST
Dynasty DGRC364CB RANGE - F/S GAS STAINLESS ST
Dynasty DGRC364G RANGE - F/S GAS STAINLESS ST
Dynasty DGRC365WOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRC366 RANGE - F/S GAS STAINLESS ST
Dynasty DGRC486G RANGE - F/S GAS STAINLESS ST
Dynasty DGRC605GCBWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRC606G RANGE - F/S GAS STAINLESS ST
Dynasty DGRC607CBWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRC607GWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRC608 RANGE - F/S GAS STAINLESS ST
Dynasty DGRC609WOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRS304 RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC2486CB RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC304 RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC364CB RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC364G RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC365WOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC366 RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC484G RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC484GCB RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC485CBWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC485GWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC486CB RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC486G RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC487WOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC488 RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC605GCBWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC606CBCB RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC606G RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC606GCB RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC607CBWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC607GWOK RANGE - F/S GAS STAINLESS ST
Dynasty DGRSC609WOK RANGE - F/S GAS STAINLESS ST
Frigidaire DGS100CD1 Kel(v2) / Gas Dryer
Frigidaire DGS100CW1 Kel(v1) / Gas Dryer
Maytag DGS30PC1 MANUAL, PARTS (DRYER GAS)
Frigidaire DGSFL0 Frg(v6) / Gas Dryer
Frigidaire DGSFL1 Frg(v6) / Gas Dryer
Frigidaire DGSFL2 Frg(v6) / Gas Dryer
Frigidaire DGSFL3 Frg(v6) / Gas Dryer
Frigidaire DGSFL4 Frg(v6) / 27 " Gas Dryer
Frigidaire DGSFW0 Frg(v5) / Gas Dryer
Frigidaire DGSFW1 Frg(v5) / Gas Dryer
Frigidaire DGSFW2 Frg(v5) / Gas Dryer
Frigidaire DGSFW3 Frg(v5) / Gas Dryer
Frigidaire DGSFW4 Frg(v5) / 27 " Gas Dryer
Frigidaire DGT400A0D Kel(v19) / Dryer
Frigidaire DGT400A0T Kel(v20) / Dryer
Frigidaire DGT400A0W Kel(v21) / Dryer
Frigidaire DGT400A1D Kel(v20) / Dryer
Frigidaire DGT400A1T Kel(v21) / Dryer
Frigidaire DGT400A1W Kel(v22) / Dryer
Frigidaire DGT400F1D Kel(v12) / 27 " Gas Dryer
Frigidaire DGT400F1W Kel(v10) / 27 " Gas Dryer
Frigidaire DGT400F2D Kel(v12) / 27 " Gas Dryer
Frigidaire DGT400F2W Kel(v10) / 27 " Gas Dryer
Frigidaire DGT400G1D Kel(v9) / 27 " Gas Dryer
Frigidaire DGT400G1J Kel(v8) / 27 " Gas Dryer
Frigidaire DGT400G1W Kel(v7) / 27 " Gas Dryer
Frigidaire DGT400G2D Kel(v9) / 27 " Gas Dryer
Frigidaire DGT400G2W Kel(v7) / 27 " Gas Dryer
Frigidaire DGT400G3D Kel(v8) / 27 " Gas Dryer
Frigidaire DGT400G3J Kel(v9) / 27 " Gas Dryer
Frigidaire DGT400G3W Kel(v7) / 27 " Gas Dryer
Frigidaire DGT400G4D Kel(v6) / 27 " Gas Dryer
Frigidaire DGT400G4W Kel(v5) / 27 " Gas Dryer
Frigidaire DGT400KD1 Kel(v6) / 27 " Gas Dryer
Frigidaire DGT400KD2 Kel(v6) / 27 " Gas Dryer
Frigidaire DGT400KW1 Kel(v5) / 27 " Gas Dryer
  #2 (permalink)
Old 05-14-2014, 06:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Sounds like you wired it wrong.
The single connector end should be C (common) and goes to power.
On the double connector end.
One is NC (normally closed), this should go to the drum light.
The other is NO (normally open), this goes to the motor.
I am on the road and do not have access to a lot of info so cannot give you wire colors.
__________________
  #3 (permalink)
Old 05-14-2014, 08:04 AM
Junior Member
Default
Hi thanks for your help, in replacing the blower cage I did not remove any wires to the door switch, it was left intact.
  #4 (permalink)
Old 05-14-2014, 04:42 PM
Senior Expert
APP Volunteer
Default
Since I am on the road I cannot get you the wiring diagram which is what you need.
I can tell you that the motor has a centrifugal switch on it which activates when the motor gets close to operating speed.
It disconnects the motor's start winding which would over heat the motor if left on.
It also provides an alternate/parallel circuit path around the start switch, this keeps the unit running when you release the start button.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
compactor reverse switch position irv6744 Trash Compactor Repair 0 12-15-2012 01:31 AM
GE Microwave all operates but no heat Wych Microwave Repair 5 09-28-2012 07:42 PM
Only operates at slow speed Tanglewood Washer Repair 1 07-20-2009 05:53 AM
Oven only operates after numerous tries DaleA Oven Repair (including Ranges and Cooktops) 1 02-24-2009 09:39 PM
Spacesaver operates but doesn't heat goecker Microwave Repair 0 09-28-2007 07:42 PM
