Discuss
third PCB assembly, why isi it faling?
 in
Dryer Repair
I have Amana electric dryer, purchased in 2009. Worked great until last October, had no heat. Would start, drum spun
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » third PCB assembly, why isi it faling?
  #1 (permalink)
Old 05-12-2014, 06:40 AM
Junior Member
rrkkcwood is on a distinguished road
Default third PCB assembly, why isi it faling?
Model Number: ned7200   Brand: Amana   Age: 1 - 5 years
I have Amana electric dryer, purchased in 2009. Worked great until last October, had no heat. Would start, drum spun and would complete time cycle, just not dry clothes. Investigated and found 240v heater relay on control board melted and smelled burnt. While I had it apart, I checked all components, including thermostats, thermistors, heater element, door switch, sensor. everything was okay. Unit ran for 6 months and last week found same problem, heater relay burned and melted, first inch of wire connected to relay burnt. Appliance pros warranteed the control board and I reinstalled. It ran for 5 loads on sensor dry, first load on time dry caused heater relay to burn up. All components are within spec, there are no shorts. What am I missing? Please help.
Related Models
Maytag NED7200TW10 29" ELECTRIC DRYER
Maytag NED7300WW0 27" ELECTRIC DRYER
Maytag NED7300WW1 27" ELECTRIC DRYER
Maytag NED7500VM0 ELECTRIC DRYER
Maytag NED7500VM1 ELECTRIC DRYER
Maytag NED7500VW0 ELECTRIC DRYER
Maytag NED7500VW1 ELECTRIC DRYER
Maytag NEDNS249F REF - SXS/I&W
Maytag NEDNS249FA REF - SXS/I&W
Maytag NEDNS249FH REF - SXS/I&W
Maytag NEDNS249HA REF - SXS/I&W
Maytag NEDNS249HH REF - SXS/I&W
Norge NEF3G1 RANGE- F/S STD ELE
Norge NEH2H0 RANGE- F/S STD ELE
Norge NEHA86-1 RANGE- S/C F/S ELE
Norge NEHW86-1 RANGE- S/C F/S ELE
Bosch NEM732 UC
Bosch NEM735 UC
Bosch NEM736 UC
Bosch NEM932 UC
Bosch NEM935 UC
Bosch NEM936 UC
Maytag NENS207G REF - SXS/I&W
Maytag NENS207GA REF - SXS/I&W
Maytag NENS207GH REF - SXS/I&W
Maytag NENS208GZA REF - SXS
Maytag NENS208GZH REF - SXS
Maytag NENS208GZW REF - SXS
Maytag NENS227F REF - SXS
Maytag NENS227FH REF - SXS
Maytag NENS227G REF - SXS
Maytag NENS227GA REF - SXS
Maytag NENS227GH REF - SXS
Maytag NENS228GZA REF - SXS
Maytag NENS228GZH REF - SXS
Maytag NENS228GZW REF - SXS
Maytag NENS248GZA REF - SXS
Maytag NENS248GZH REF - SXS
Maytag NENS248GZW REF - SXS
Maytag NENT156E REF - TOP MOUNT
Maytag NENT156EA REF - TOP MOUNT
Maytag NENT156EH REF - TOP MOUNT
Maytag NENT156G REF - TOP MOUNT
Maytag NENT156GA REF - TOP MOUNT
Maytag NENT156GH REF - TOP MOUNT
Maytag NENT156HA REF - TOP MOUNT
Maytag NENT156HH REF - TOP MOUNT
Maytag NENT156HW REF - TOP MOUNT
Maytag NENT176H REF - TOP MOUNT
Maytag NENT176HA REF - TOP MOUNT
Maytag NENT176HH REF - TOP MOUNT
Maytag NENT196H REF - TOP MOUNT
Maytag NENT196HA REF - TOP MOUNT
Maytag NENT196HH REF - TOP MOUNT
Maytag NENT198H REF - TOP MOUNT
Maytag NENT198HA REF - TOP MOUNT
Maytag NENT198HH REF - TOP MOUNT
Maytag NENT198K REF - TOP MOUNT
Maytag NENT198KA REF - TOP MOUNT
Maytag NENT217F REF - TOP MOUNT
Maytag NENT217FA REF - TOP MOUNT
Maytag NENT217FH REF - TOP MOUNT
Maytag NENT238H REF - TOP MOUNT
Maytag NENT238HA REF - TOP MOUNT
Maytag NENT238HH REF - TOP MOUNT
Norge NER1360ACW RANGE- F/S STD ELE
Admiral NER1360AGH RANGE- F/S STD ELE
Norge NER3540ACW RANGE- S/C F/S ELE
Norge NER3760ACW RANGE- S/C F/S ELE
Bosch NES732 UC
Bosch NES735 UC
Bosch NES736 UC
Bosch NES932 UC
Bosch NES935 UC
Bosch NES936 UC
Norge NEW2G1 RANGE- F/S STD ELE
Norge NEW2H0 RANGE- F/S STD ELE
Norge NEW2H1 RANGE- F/S STD ELE
Norge NEW3G1 RANGE- F/S STD ELE
Norge NEW3G8AC RANGE- S/C F/S ELE
Norge NEW3G8CV RANGE- S/C F/S ELE
Norge NEW3G8CX RANGE- S/C F/S ELE
Norge NEW3G8DEV RANGE- S/C F/S ELE
Norge NEW3G8DX RANGE- S/C F/S ELE
Norge NEW3G8EV RANGE- S/C F/S ELE
Norge NEW3G8EVW RANGE- S/C F/S ELE
Norge NEW3H2EX RANGE- F/S STD ELE
Norge NEW3H8CVW RANGE- S/C F/S ELE
Norge NEW3H8CX RANGE- S/C F/S ELE
Norge NEW3H8STVW-EV RANGE- S/C F/S ELE
Norge NEW3J8EV RANGE- S/C F/S ELE
Norge NEW6G6CLW RANGE- F/S CONT CLEAN ELE
Norge NEW6H6CLW RANGE- F/S CONT CLEAN ELE
Bosch NEZ1000
Bosch NEZ1010
Bosch NEZ1020
Bosch NEZ1050
Bosch NEZ1055
Bosch NEZ1070
Bosch NEZ1075
Bosch NEZ1100
Frigidaire NFTR18X4LB0 REFRIGERATOR
Frigidaire NFTR18X4LB1 REFRIGERATOR
Frigidaire NFTR18X4LB2 REFRIGERATOR
Frigidaire NFTR18X4LB4 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LB6 REFRIGERATOR
Frigidaire NFTR18X4LS2 REFRIGERATOR
Frigidaire NFTR18X4LS3 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LS4 REFRIGERATOR
Frigidaire NFTR18X4LS5 REFRIGERATOR
Frigidaire NFTR18X4LS6 REFRIGERATOR
Frigidaire NFTR18X4LW0 REFRIGERATOR
Frigidaire NFTR18X4LW1 REFRIGERATOR
Frigidaire NFTR18X4LW2 REFRIGERATOR
Frigidaire NFTR18X4LW4 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LW6 REFRIGERATOR
Maytag NFW7200TW10 AUTOMATIC WASHER
Maytag NFW7200TW11 AUTOMATIC WASHER
Maytag NFW7300WW00 AUTOMATIC WASHER
Maytag NFW7500VM00 AUTOMATIC WASHER
  #2 (permalink)
Old 05-14-2014, 06:25 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I can only think of couple things.
1. Check your power to make syre that the unit is getting 240 volts.
Do this with the unit off and when it is running.
2. Unplug the unit and both wires at the heater.
Measure the heater, should be 8 to 12 ohms.
Then measure from each side of the heater to the case, both should be infinite ohms. If not the element is grounded and should be replaced.
__________________
  #3 (permalink)
Old 05-14-2014, 07:47 AM
Junior Member
Default No luck
Thanks for the input, heater is not shorted to ground. I have 9.7 ohms resistance. Input voltage is solid 242 v. No drop during 5 min run. All connections are tight at panel, receptacle and block.
Question back to you, how much resistance should a 6' dryer cord have? Prongs to lugs vary from 0.1- 0.3 ohms. Is it possible the dryer cord is bad?
  #4 (permalink)
Old 05-14-2014, 04:46 PM
Senior Expert
APP Volunteer
Default
Your cord resistance looks OK to me.
If you got the 242 volts at the unit's terminal strip when running the
n the power cord is good.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dis-assembly help manders Oven Repair (including Ranges and Cooktops) 0 05-14-2011 02:00 PM
Tub assembly Barney Maynard Washer Repair 1 09-30-2010 01:47 AM
Can't get the Tub assembly out. CobraKR101 Washer Repair 1 07-02-2010 02:46 AM
Assembly help Jim Cope Refrigerator & Freezer Repair 0 04-04-2008 07:49 AM
mag fan assembly vijay m Microwave Repair 0 04-01-2008 02:12 PM
