| » getting to heating element |
Model Number: 47-2251-00-02 Brand: Tappan Age: 5 - 10 years
The dryer will not heat. I'd like to get to the heating element to check it.
The top has been popped off, the door removed, the belt off the tension pulley. I don't see how to get the back panel or the drum off. Related Models |
Quote:
With the top hinged back, you should see a screw in each upper corner holding the front on. Once the front is removed, the drum will come out by popping it out of the socket that holds it in the back. Visualize a ball and socket, the ball is attached to the back side of the drum. The socket is mounted to the back of the dryer cabinet. Behind the drum you will find the heating element. Below is a picture of the element. Part number: AP2134386
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Heating coil or Heating element assembly | jayclagg | Dryer Repair | 1 | 02-11-2010 07:26 AM |
| Heating Element On/Off buttons don't work. Element stays on mostly. | juliotamu01 | Dishwasher Repair | 0 | 11-13-2009 06:05 AM |
| Replaced heating element now heating element nor broil element work, all else does | rontetley | Oven Repair (including Ranges and Cooktops) | 1 | 10-26-2009 01:30 PM |
| bake element not heating but broil element heating okay | horno | Oven Repair (including Ranges and Cooktops) | 1 | 10-04-2009 11:37 AM |
| Heating element stopped heating JSP38G0T1BB | Gravity Railroad | Oven Repair (including Ranges and Cooktops) | 1 | 06-23-2009 02:10 PM |
