Hello ,I have a Duet GGW9250PW1 that has the audible beep and a click within the machine control electronics when I try to start it.
I have went through the onboard diagnostics and the door switch is ok. I have checked for continuity within the thermal fuse and it is ok.
While doing the motor circuit test, the resistance between P1-3 and P1-4 was 1.6 ohms. The troubleshooting says if resistance is between 1 and 6 ohms replace the machine control electronics.
Has anyone seen this before? I am looking for some confirmation before I spend $216.15 on the AP3775548.
