bluebeast1562
#1 Posted : Saturday, April 19, 2014 8:34:11 AM(UTC)
bluebeast1562
As the title says, not heating. I have replaced everything, fuse, heating element, and all the other thermostats, good continuity. Still not heating. Any ideas?
fairbank56
#2 Posted : Saturday, April 19, 2014 10:06:59 AM(UTC)
fairbank56
Groups: Expert
Timers on these models are cheap and a common failure item but first check for 240vac at terminal block. Try resetting panel breaker first. If that doesn't do it, unplug dryer, remove the small cover on rear to expose terminal block. Check that terminals are tight and there is no burning/melting of any wires there. Plug dryer back in and check for 240vac across outer terminals. If good, replace timer. Problem could also be a bad motor switch but more likely the timer.
Whirlpool W10185970 Timer - AppliancePartsPros.com
Eric
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Still not heating (Dryer Repair)
by artinmartin 10/23/2023 2:36:57 PM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 4/12/2023 12:28:01 PM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Kenmore Elite HE3 not heating and drum not spinning (Dryer Repair)
by Guest 12/23/2022 11:32:17 AM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 7/24/2022 9:39:41 AM(UTC)
Samsung Gas Dryer Model DV42H5000GW/A3 not heating (Dryer Repair)
by mikeb22 6/1/2022 9:47:03 AM(UTC)
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 5/23/2022 12:46:49 PM(UTC)
Samsung DV395ETPASU/A1 not heating (Dryer Repair)
by Guest 3/5/2022 5:01:06 PM(UTC)
Bosch washer not heating (Washer Repair)
by Guest 2/6/2022 2:10:46 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Samsung dryer DV42H5200 still not heating after replacing all components (Dryer Repair)
by Guest 1/9/2022 11:26:52 AM(UTC)
