Discuss
Bosch Dryer does not work
 in
Dryer Repair
I have had my bosch dryer for just over a year (warranty not applicable) and for the past 3 weeks
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Bosch Dryer does not work
  #1 (permalink)
Old 02-15-2008, 08:09 AM
ldonts1 ldonts1 is offline
Junior Member
ldonts1 is on a distinguished road
Default Bosch Dryer does not work
Model Number: wtmc 6500 uc /01   Brand: Bosch   Age: 1 - 5 years
I have had my bosch dryer for just over a year (warranty not applicable) and for the past 3 weeks the dryer turns off with out finishing the cycle and I get an error message E0:1 and the lint filter light starts blinking. I have cleaned out the filter several times and nothing works. It has gotten so bad that I can not dry my clothes and it all smells. Any help would be appreciated.
Lana
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-29-2008, 10:55 AM
Servicer Servicer is offline
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Hello,
The E:01 is a code that is generated when the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting. You may need to have it cleaned out. I've also seen this if the lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex if this is a possibility.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, Bosch part number 154166, or there may be heat escaping somewhere within the dryer.
  #3 (permalink)
Old 09-25-2008, 04:43 PM
Dryer Dad Dryer Dad is offline
Junior Member
Dryer Dad is on a distinguished road
Default Bosch Lint filter prob
First poster had it right. It's in the duct work and probably outside where the duct work exits.
The trap door on the dryer vent may be full of lint and not letting the hot air pass. This might be esp true if the vent has a rodent barrier. The lint has collected on the barrier and is blocking the airflow.
Check the outside vent.
  #4 (permalink)
Old 09-25-2008, 04:45 PM
libertyappl libertyappl is online now
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check you venting system all thru the dryer, it may have a blockage, causing it to shut down and smell.
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Axxis dryer problem Chipper Dryer Repair 2 04-01-2008 06:43 PM
Dryer won't work calford Dryer Repair 0 02-02-2008 12:40 PM
bosch nexxt dlx dryer (wtmc4500uc) causing 'burning' smell washer05 Dryer Repair 0 12-29-2007 11:39 AM
Bosch Dryer Frank Titoni Dryer Repair 0 09-01-2007 10:26 AM
HELP!!! Dryer doesn't work a dbrenvic4 Dryer Repair 1 07-30-2007 03:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
