sam97202
#1 Posted : Tuesday, October 20, 2009 7:48:37 AM(UTC)
sam97202
My dryer is no longer giving off heat. I called and was told it could be one of three issues - heating element, safety thermostat or thermal fuse? Just wondering what is the most likely flaw so that I don't have to purchase all parts.
#2 Posted : Tuesday, October 20, 2009 9:01:02 AM(UTC)
Replacement parts for WHIRLPOOL LXE5700W0 | AppliancePartsPros.com
First I would try turning the breaker off/on slowly a couples times. Sometimes you can loose half the line without tripping the breaker and the heater requires the full 240 volts. The motor only requires 120.
If this does not work I would measure it with a meter.
L1 to L2 should be 140 volts
L1 to Neutral and L2 to Neutral should be 120 volts.
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Kenmore Gas Dryer - No Heat (Dryer Repair)
by smackover 10/6/2018 5:55:17 PM(UTC)
Whirlpool Duet dryer - no heat (Dryer Repair)
by colino 3/19/2018 10:56:53 AM(UTC)
Kenmore HE3 dryer - no heat (Dryer Repair)
by tdalton 10/2/2017 1:20:19 PM(UTC)
Samsung Dryer - No Heat (Dryer Repair)
by SolomonMan 6/6/2017 10:12:22 AM(UTC)
Kenmore Series 90 Dryer - No Heat (Dryer Repair)
by walt0132 2/22/2015 12:35:59 PM(UTC)
Electric Dryer - No Heat (Dryer Repair)
by kevinlp 10/1/2014 4:28:52 AM(UTC)
Roper Dryer - No heat (Dryer Repair)
by Raider Dana 12/6/2013 4:51:57 AM(UTC)
Whirlpool Duet Dryer - No Heat (Dryer Repair)
by BobBear4 8/24/2013 5:13:45 AM(UTC)
Amana dryer - no heat (Dryer Repair)
by Bthomas67wagon 2/26/2013 3:20:55 PM(UTC)
Electric Whirlpool Dryer - no Heat! (Dryer Repair)
by willow5000 2/5/2013 10:51:32 AM(UTC)
Whirlpool Dryer - No heat, Timer Does Not Advance (Dryer Repair)
by katielove22 10/21/2012 12:26:02 PM(UTC)
Estate Electric Dryer - No Heat (Dryer Repair)
by Porkface 5/26/2012 1:49:09 PM(UTC)
by Porkface 5/26/2012 1:47:21 PM(UTC)
