Dry way running with light load then quit. checked power to dryer then, all accessible switches with ohm meter. the heat element included. I`m down to the main electronic panel and motor. No burn signs on the main panel, however, there is a slight overheat smell coming from the little transformer mounted in the center. I don`t know how to check the motor. any support out there? i do appreciated all the help I can get. Jack
