Discuss
Kenmore Heavy Duty 70 Dryer
 in
Dryer Repair
Hi, I moved into a new apartment and there has been this old dryer under the counter in the kitchen
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Heavy Duty 70 Dryer
  #1 (permalink)
Old 10-19-2009, 06:59 PM
Junior Member
Nicholas482109 is on a distinguished road
Default Kenmore Heavy Duty 70 Dryer
Brand: Kenmore   Age: More than 10 years
Hi, I moved into a new apartment and there has been this old dryer under the counter in the kitchen since. This weekend we pulled it out and were surprised it worked. I decided to use it today to see if it dried my clothes. After about an hour I thought something with the dryer was broken since it did not seem to heat up. I checked it about 1 and half hours in and noticed that it is getting warm inside, although only slightly.
Since we do not have any duct connected to it we are running it on our back porch. the temperature is around 40 F outside and its not making any visible exhaust and the exhaust doesn't feel very warm at all. Does anyone have any ideas why this is working this way?
M# 110.78670100
  #2 (permalink)
Old 10-21-2009, 11:08 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The chances are extremely high that it is fully clogged with lint. You are going to have to open it and clean it out everywhere, but particularly in the lint chute or lint exhaust from the drum past the blower to the outside. Also clean lint off the intake and outflow grids in the dryer.
A dryer in an apartment is almost certain to have this problem. Do not use it again until you have done this as it is a fire hazard.
Good luck.
__________________
  #3 (permalink)
Old 10-21-2009, 01:03 PM
Junior Member
Default
Thanks for the reply, I cleaned the exhaust shoot yesterday but not the intake and there was a great deal of lint trapped everywhere. Is there anyway of cleaning it easily? I flushed it in my tub but that did not get everything and picking out the lint is time consuming and the grate cut my hand. Is there anything that will break the lint down?
  #4 (permalink)
Old 10-21-2009, 01:18 PM
Senior Expert
APP Volunteer
Default
Yes there is an easy way, but it may not be available to you.
What we do is take out the drum and then use compressed air to blow out everything (obviously we have to do this outdoors). If you cannot do this then as powerful a vac as you have is the best you can do. Also, take off the console as believe it or not there will be a large amount of lint in there also.
I know this is a struggle, particularly since it is not yours but this is time well spent. The only way your dryer will work well is to get all of that lint out and have free flowing air. The only way you will not to set your place on fire is to get all of that lint out.
As my hero Larry the Cable Guy says, "git'er done"
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Heavy Duty SOft Heat Dryer lostirishguy Dryer Repair 0 02-21-2010 09:09 PM
Kenmore 70 Series Heavy Duty Plus Washer meagansmommy Washer Repair 1 07-13-2009 01:48 PM
Kenmore 90 Plus Series Heavy Duty washer Betty Moore Washer Repair 1 04-06-2009 10:47 AM
Kenmore Heavy Duty 70 Series jenna Washer Repair 3 04-29-2008 08:03 PM
kenmore heavy duty 60 washing machine Ben Anson Washer Repair 1 08-10-2007 05:49 PM
