JimHays
#1 Posted : Monday, March 17, 2014 4:44:46 PM(UTC)
JimHays
Whirlpool gas touch pad dyer won't power up, can't be placed in diagnostic
test mode. Checked for 120vac to terminal strip p1-5 on control mod. With
AC off checked continuity between AC Plug neutral plug to p1-3 with door
closed. Checked for continuity between p1-3 and p1-2 with door closed, no
continuity with door open. AC on door open interior drum light lit. Tested
user interface touch pad per page 11 chart, all keys and terminal pin placements gave proper response. According to page 11 box notes if test
passes replace ECM Control Board, also page 5 Test 1 Supply Connections,
Step's 1-6, continuity on Step 5 & 6, advised to replace Electronic Control
Module. Have replaced Control Module with component from AppliancePartsPros, still no lights on panel. Whats next step?
