Oh....I hope someone can help me!! My dryer has been making awful noises.....like it's tumbling rocks.
So far, I have replaced the following: Rear Drum Bearing Lower Front Felt Drum Seal Idler Pulley Wheel (which was broken) Drive Belt (also broken) Front Drum Bearing & all 4 slides
After all that it still makes tumbling rock noise.
BUT.......I have just learned that I may need to use a circlip on the rear bearing. When I originally took the drum out, I found that little circlip on the floor of the dryer ..... had no idea what it was. But now I'm wondering where it goes on the rear bearing.......do I need it? Could that piece missing be causing the awful noise?
If I need to use it....how do I install it? I don't know where it goes.........
