LG Dryer - Model DLE7177RM
Problem: Takes 2-3 cycles to dry clothes completely. When new, only one cycle was required. Vent is clear and clean. Drum gets hot when using Speed Dry cycle so I don't think the problem is the coil. Unit is equipped with 2 moisture sensors. One located just inside door, another located internally near motor. How do I determine which (if any) sensor needs replacement? Or if it's even the sensors causing the problem?
