islanbplumb
#1 Posted : Monday, March 10, 2014 12:22:27 PM(UTC)
islanbplumb
hi,
my gas dryer dosen't shut off when on auto cycle, but works fine on timed setting. what is the part that i need to order?
islanbplumb
#2 Posted : Monday, March 10, 2014 12:25:08 PM(UTC)
islanbplumb
well not sure if its more then 10 years old. i just had to change the belt. and the next day, this was the problem.
fairbank56
#3 Posted : Monday, March 10, 2014 1:09:04 PM(UTC)
fairbank56
Groups: Expert
This is an 02 model. Does timer advance at all in auto dry or just not advancing to OFF when it gets to end of cycle? Is it drying clothes in normal amount of time? If timer doesn't advance at all in auto dry, you probably just need to clean the moisture sensing bars. If it does advance but stops short of going into OFF position, timer is bad.
Eric
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
Knocking noise from my ge gas dryer. (Dryer Repair)
by Lougaal 2/16/2023 9:40:08 AM(UTC)
Gas Dryer turns off early (Dryer Repair)
by giorfido 12/31/2022 8:36:38 AM(UTC)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
