We were getting lines on laundry and the rear rollers were shot so I replaced both felt seals, the rear rollers and shafts. Now on reassembly the drum is turning slower than normal with a slight bumping noise. Everything appeared normal on reassembly. Seals were kept outside of drum edge, belt seems to be in proper location. Could slower rotation be just from fresh felt seals?
Thanks in advance for any help, JS
