Discuss
Dryer won't run
 in
Dryer Repair
When I push the start button nothing happens. There is no light inside the dryer either. I turned the fuse
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't run
  #1 (permalink)
Old 10-18-2009, 08:01 PM
SQP SQP is offline
Junior Member
SQP is on a distinguished road
Default Dryer won't run
Model Number: LNC7764A71   Brand: Admiral   Age: 5 - 10 years
When I push the start button nothing happens. There is no light inside the dryer either. I turned the fuse on and off an couple of times and no change.
Related Models
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
  #2 (permalink)
Old 10-19-2009, 06:26 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Check at the unit to be sure you have the correct power.
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral should be 120 volts.
Sounds like you have lost half the line as normally the motor and the light use the same side of the line.
The door switch is Normally Closed power to the light and Normally open power to the motor.
__________________
  #3 (permalink)
Old 10-26-2009, 01:14 AM
SQP SQP is offline
Junior Member
Default
My husband checked the outlet and it's working correctly. The breaker is also working. The problem seems to be with the dryer.
Thank you so much for your time.
  #4 (permalink)
Old 10-26-2009, 03:48 AM
Senior Expert
APP Volunteer
Default
Control panel replacement parts for ADMIRAL LNC7764A71 | AppliancePartsPros.com
I cannot find a wiring diagram for this unit. If you do not have it look in the control console, they like hiding it in there.
Try different settings/cycle types to see if it will start.
Though on most dryers the interior light is not wired through the timer, it is worth a shot.
Check that a wire has not burned off at the terminal strip in the machine.
Next check the door switch
After that check the thermal fuse on the heater.
Here is a good site with basic dryer help
http://www.applianceaid.com/dryers.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
