| » dryer start but stops when I release start button |
Model Number: gold series Brand: Whirlpool Age: 5 - 10 years
Dry starts but stops when I release the start button
A Model Number may help others help you.
There are a number of different methods for keeping a unit on after the Start is released so a Model Number is required. This may help you find it. Model Number Locator
__________________
Here is the tech sheet
http://www.servicematters.com/docs/w...%203978618.pdf See Page 6, sounds like the Motor Relay i9s not closing or it's contacts are shot. Usually with relays I check the coil for continuity first just to be sure that it is not burned out.
__________________
Here is the parts breakdown
Section replacement parts for WHIRLPOOL GEQ9858JQ0 | AppliancePartsPros.com Relay is Item 23 in Section 2
__________________
So the motor relay is not located on the motror, but in the top housing. My question there re two relays in the top section with number 23 one is near item 31 the other near itme 25, which one is the motor start up relay.
| Display Modes | |
| whirlpol dryer won't start-just hums when I push the start button | bdubois | Dryer Repair | 27 | 02-18-2010 07:36 PM |
| Drier stops when you release start switch | jhall82891 | Dryer Repair | 4 | 06-12-2009 04:18 AM |
| Kenmore Dryer won't start unless PTS (push to start) button depressed and held | trp | Dryer Repair | 1 | 06-07-2009 06:13 AM |
| Stops when push to start button is released | Burgbrd | Dryer Repair | 4 | 01-02-2008 07:48 PM |
| Dryer stops running after letting off the Start button | Andy | Dryer Repair | 10 | 08-01-2007 09:56 PM |
