cnrimgr1
#1 Posted : Monday, February 17, 2014 12:27:23 PM(UTC)
cnrimgr1
when i push the start button it buzzes but does not come on.. Any suggestions would be helpful.
#2 Posted : Wednesday, February 19, 2014 3:14:23 AM(UTC)
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
Belarus k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by Tom Kerr 2/2/2014 8:30:02 AM(UTC)
