Recently replaced the control board and now the time remaining goes off after about 10 minutes and shows lights chasing around the board. The dryer works fine and turns off when it should. Also, if I push the pause button the time resets to the original amount of time instead of the time remaining. Did I install the control board wrong or did something else go out?
