Discuss
NO grey wire for my motor?
 in
Dryer Repair
Hi guys need help. Motor had a loud buzzing before so i got a new motor. I got the motor
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » NO grey wire for my motor?
  #1 (permalink)
Old 02-12-2014, 09:27 PM
Junior Member
kiyoshi is on a distinguished road
Default NO grey wire for my motor?
Model Number: DG308   Brand: Maytag   Age: More than 10 years
Hi guys need help.
Motor had a loud buzzing before so i got a new motor. I got the motor and the wiring diagram is pretty self explanatory the stuff i can read... really bad xerox. its says that L1 is a grey wire and needs to be in the thermal protector tab, problem is there is no grey wire? and there aren't any spare wires. So where is this grey wire supposed to be wired to? i assume it is a hot wire since right now my timer works ( i hear ticking) but the motor does not turn. need help or could you point me into the right resources?
erik
Related Models
Maytag DG308 DRYER- GAS
Maytag DG309 DRYER- GAS
Maytag DG30CA MANUAL, PARTS (DRYER GAS)
Maytag DG30CM MANUAL, PARTS (DRYER GAS)
Maytag DG30CMD MANUAL, PARTS (DRYER GAS)
Maytag DG30CT MANUAL, PARTS (DRYER GAS)
Maytag DG30MC1 MANUAL, PARTS (DRYER GAS)
Maytag DG30PC1 MANUAL, PARTS (DRYER GAS)
Maytag DG30PN1 MANUAL, PARTS (DRYER GAS)
Maytag DG312 DRYER- GAS
Maytag DG313 DRYER- GAS
Maytag DG31CA MAYTAG LAUNDRY (DRYER GAS)
Maytag DG31CM MAYTAG LAUNDRY (DRYER GAS)
Maytag DG31CT MAYTAG LAUNDRY (DRYER GAS)
Amana DG3240 WASHER-TOP LOADING
Amana DG3250 WASHER-TOP LOADING
Amana DG3261 WASHER-TOP LOADING
Amana DG3280 WASHER-TOP LOADING
Amana DG3281 WASHER-TOP LOADING
Amana DG3291 WASHER-TOP LOADING
Maytag DG32CA MAYTAG LAUNDRY (DRYER GAS)
Maytag DG32CM MAYTAG LAUNDRY (DRYER GAS)
Maytag DG32CT MAYTAG LAUNDRY (DRYER GAS)
Amana DG3300 WASHER-TOP LOADING
Amana DG3331 WASHER-TOP LOADING
Amana DG3341 WASHER-TOP LOADING
Amana DG3350 WASHER-TOP LOADING
Maytag DG33CA MANUAL, PARTS (DRYER GAS)
Maytag DG33CM MAYTAG LAUNDRY (DRYER GAS)
Maytag DG34CD MAYTAG LAUNDRY (DRYER GAS)
Maytag DG34CQ MAYTAG LAUNDRY (DRYER GAS)
Frigidaire DG350RXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW3 Wwh(v2) / 27 " Gas Dryer
Amana DG3630 WASHER-TOP LOADING
Amana DG3680 WASHER-TOP LOADING
Amana DG3681 WASHER-TOP LOADING
Amana DG3800 WASHER-TOP LOADING
Amana DG3801 WASHER-TOP LOADING
Maytag DG382 DRYER- GAS
Amana DG3860 WASHER-TOP LOADING
Amana DG3861 WASHER-TOP LOADING
Frigidaire DG3900ADD1 Frg(v6) / 27 " Gas Dryer
Frigidaire DG3900AWW1 Frg(v5) / 27 " Gas Dryer
Maytag DG4000 DRYER- GAS
Frigidaire DG400AXD1 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXD2 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXW1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400AXW2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG400EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG400EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG400EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG400EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG400EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG400EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG400EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG400EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG400EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG400EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG400EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG400EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG400EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG400JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG400JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG400JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG400JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG400KXD1 Wwh(v9) / Gas Dryer
Frigidaire DG400KXD2 Wwh(v9) / 27 " Gas Dryer
Frigidaire DG400KXD3 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD4 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD5 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXH1 Wwh(v8) / Gas Dryer
Frigidaire DG400KXH2 Wwh(v8) / 27 " Gas Dryer
Frigidaire DG400KXH3 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXH5 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXW1 Wwh(v7) / Gas Dryer
Frigidaire DG400KXW2 Wwh(v7) / 27 " Gas Dryer
Frigidaire DG400KXW3 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW4 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400SXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400SXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD0 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXW0 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400TXW1 Wwh(v2) / 27 " Gas Dryer
Maytag DG406 DRYER- GAS
Maytag DG407 DRYER- GAS
Maytag DG408 DRYER- GAS
Maytag DG409 DRYER- GAS
Maytag DG410 DRYER- GAS
Maytag DG412 DRYER- GAS
Maytag DG482 DRYER- GAS
Maytag DG490 DRYER- GAS
Maytag DG4910 DRYER- GAS
Maytag DG500 DRYER- GAS
Frigidaire DG500AXD5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXW5 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500AXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500EXD1 Wwh(v16) / Gas Dryer
Frigidaire DG500EXD4 Wwh(v17) / Gas Dryer
Frigidaire DG500EXD5 Wwh(v18) / Gas Dryer
Frigidaire DG500EXF1 Wwh(v19) / Gas Dryer
Frigidaire DG500EXF4 Wwh(v20) / Gas Dryer
Frigidaire DG500EXF5 Wwh(v21) / Gas Dryer
Frigidaire DG500EXH1 Wwh(v22) / Gas Dryer
Frigidaire DG500EXH4 Wwh(v23) / Gas Dryer
Frigidaire DG500EXH5 Wwh(v24) / Gas Dryer
Frigidaire DG500EXV1 Wwh(v25) / Gas Dryer
Frigidaire DG500EXV4 Wwh(v26) / Gas Dryer
Frigidaire DG500EXV5 Wwh(v27) / Gas Dryer
  #2 (permalink)
Old 02-12-2014, 09:47 PM
Junior Member
Default
okay so i finally found a post that had my problem. I am currently using the white wire to replace the grey wire. Everything is where it should be or so i thought. The motor will still not turn on. Right now i have the tumbler out and basically just the motor and burner in the dryer housing. i connected together the door switch. So my logic says it should spin. I know i get 120v at the white wire when i touch the ground and the red terminal 5. now that i know i have voltage... should i now look at the switch? how do i bypass it? just connect it?
  #3 (permalink)
Old 02-12-2014, 09:58 PM
Junior Member
Default
okay.... so i go the red and yellow wires that lead into the switch on door, and i did the same for the one on the head dial unit. then plug in dryer... nothing... im at a loss here is what i have done so far.
grey wire: no grey wire so i used the white wire ( it has 120 on it when plugged in) and has a blue jumper wire connected to it as well.
the blue wire is connected to terminal 1
the red wire is on terminal 5
the black wire is terminal 2
and i have two yellow wires which i wired together and put on terminal 6
so there a safety that i dont know?about cause i want test to make sure the motor works before i put everything back together.
  #4 (permalink)
Old 02-13-2014, 07:54 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Post the wiring diagram for your dryer.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Axxiss washer broken wire on motor wire connector plug essorjsmith Washer Repair 2 03-05-2017 02:57 PM
Whirlpool Dryer Electric Motor Wire Diagram (Want to hard wire electric motor) KubistaF Dryer Repair 0 08-14-2013 06:30 AM
Grey Wire for Lid Switch Melted mark1920 Washer Repair 6 07-17-2012 11:13 AM
new motor how to wire it up yidman Dryer Repair 0 01-25-2012 06:13 PM
The red and grey wire adrianblakey Dishwasher Repair 0 10-27-2009 06:54 AM
