Kenmore gas dryer timer not moving when using auto moisture sensing
Dryer Repair
when using auto moisture sensing the timer doesn't move at all. The dryer does heat. Had to manually stop it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore gas dryer timer not moving when using auto moisture sensing
  #1 (permalink)
Old 02-11-2014, 10:30 AM
Junior Member
dding0919 is on a distinguished road
Default Kenmore gas dryer timer not moving when using auto moisture sensing
Model Number: 110.72904100   Brand: Kenmore   Age: 5 - 10 years
when using auto moisture sensing the timer doesn't move at all. The dryer does heat. Had to manually stop it by opening the door. Otherwise, it will run forever and the clothes are getting really hot. Tried timed dry and the timer does move and turn off properly. Tried to clean sensor strips using alcohol pad but no luck. Also, cleaned lint slot where the strips connected through. Still problem. I guess it could be the sensor or maybe sensor circuit board? I managed to open the (top) console but didn't see any circuit board. Also, the sensor is on the front lint grill. I think I have to take down the whole front panel to replace the sensor strips if want to, correct? The label shows the mod is 11012904100 (assuming this is the model #) and ser ml3802300. But I can't find anything related to this model like manual or parts.
Any idea what the problem could be and how to fix it? What to get the part and part #?
Related Models
Hoover 1100
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11012202100 WASHER
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore "Auto Moisture Sensing"Sensor snags clothes dryersheet Dryer Repair 2 04-06-2013 07:29 PM
dryer only heats on moisture sensing cycle more dry setting jwilcoxen Dryer Repair 0 02-15-2012 08:51 PM
"auto moisture sensing" problems gonecampin Dryer Repair 3 11-18-2009 05:00 AM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Auto Moisture Sensing Plus not working mschmero Dryer Repair 2 01-06-2008 11:55 AM
