Discuss
Frigidaire dryer e66 code still comes up
 in
Dryer Repair
Our Frigidaire dryer is less than two years old. We recently got the e66 "door open" code and called in
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire dryer e66 code still comes up
  #1 (permalink)
Old 02-09-2014, 09:16 AM
Junior Member
redskyatnight is on a distinguished road
Default Frigidaire dryer e66 code still comes up
Brand: Frigidaire   Age: 1 - 5 years
"door open" code and called in a repair person who said the control board needed to be replaced. We put in a new one, but that didn't solve the problem. We brought in another repairman who took apart the dryer and identified the problem as a frayed wire leading to a fuse in the back of the dryer (he said the fuse and other components checked out fine). After he repaired the wiring, the unit began working again -- but for only twenty minutes at a time before shutting down (again, error code 66 came up). We thought it might be a heat buildup due to some kind of blockage in the vent, but we checked and everything is working fine on that end. Any ideas what's continuing to cause the problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Dryer error code E5 countrigirl49 Dryer Repair 1 05-22-2012 05:33 PM
Frigidaire Affinity dryer error code E61 napclan6 Dryer Repair 4 02-12-2012 06:23 PM
Error Code E04 on Frigidaire Affinity Dryer Soarer Dryer Repair 3 02-23-2011 05:18 AM
Frigidaire dryer shuts off (E68 code) surferfletch Dryer Repair 3 05-10-2010 06:00 PM
Frigidaire Affinity dryer error code E9E jpalazzi Dryer Repair 4 04-24-2010 02:20 PM
