Discuss
Kenmore Elite HE3 over heating
 in
Dryer Repair
Hello I have an Kenmore Elite HE3 dryer. The dryer was over heating and shutting down until it cooled off.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Elite HE3 over heating
  #1 (permalink)
Old 02-07-2014, 12:15 PM
Junior Member
cjgarr is on a distinguished road
Default Kenmore Elite HE3 over heating
Model Number: 110.82834100   Brand: Kenmore   Age: 1 - 5 years
Hello
I have an Kenmore Elite HE3 dryer. The dryer was over heating and shutting down until it cooled off. So here is what i have done.
1. Made sure that the exhaust was clear.
2. Replaced the thermostat.
3. Replaced the thermister.
4. Replaced the heating element.
None of this helped. The heating element has now blown out. What else could it be? Any help would be appreciated.
Thank you
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 02-07-2014, 01:17 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Does it heat when set to air dry? If so, the heat relay is stuck closed. If not, check inside of blower housing, internal exhaust duct and air duct behind back panel for lint buildup. Check that the blower wheel is not slipping on motor shaft.
Eric
  #3 (permalink)
Old 02-07-2014, 01:51 PM
Junior Member
Default
If you are talking about the high temp switch yes it has been replaced and checked to make sure it opens when heat is applied (it opens @250 degrees like its is supposed to). Everything has been cleaned and there are no obstructions. the blower wheel does not slip and turns fine. i will need to get another heating element now because it blew out. I read somewhere that it could be a controller board but cant find the post again.
  #4 (permalink)
Old 02-07-2014, 03:19 PM
Expert
APP Volunteer
Default
No, I'm not talking about the hi-limit thermostat, I'm talking about the heat relay on the machine control board. You didn't answer the question as to whether the heat is on when temp is set to air dry. The hi-limit opens at 295, not 250
Eric
  #5 (permalink)
Old 02-07-2014, 03:29 PM
Junior Member
Default
I'm not sure about the heat being on while on air dry... ill replace the heating element and let you know. The place where i got the thermostat gave me the lower unit and said it would be fine. Should i get the higher rated one? Is there a part # on the heat relay so i can look it up? and do i check it like the high temp shut off switch?
Curt
  #6 (permalink)
Old 02-07-2014, 04:19 PM
Expert
APP Volunteer
Default
Sorry, your heat element is blown so you can't answer my question. Duh. Anyway, to see if the relay is stuck closed, unplug the dryer and check continuity between power plug and red wire on the thermal cutoff. Should be open circuit (no continuity). Check both flat blades of the power plug. If you read continuity on one of the blades of the plug to the red wire, then the relay is stuck closed. The relay is an integral part of the machine control board so the whole board would have to be replaced unless you want to tackle desoldering it to replace it. The control board cycles the relay on/off which turns the heat circuit on/off to maintain proper temperature based on input from the thermistor. When you have the dryer operating again you can check to see if the relay is cycling by monitoring the voltage across it's terminals. You will have to have the board swung out of the top of the cabinet to do this. When the relay is closed calling for heat, the voltage across it's terminals (black and red wires) will be zero and when open (no heat) it will be 240vac. As far as the hi-limit thermostat, my advice is to follow manufacturer recommendations.
Eric
  #7 (permalink)
Old 02-13-2014, 11:01 AM
Junior Member
Default
Ok i replaced the heating element. I ran it on air dry and not heat. put heat on and it overheats. Not sure whats left to replace?
  #8 (permalink)
Old 02-13-2014, 11:18 AM
Expert
APP Volunteer
Default
Maybe you could do the checks that I suggested. Sounds like maybe a control board problem.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Oven bake element not heating ADN140 Oven Repair (including Ranges and Cooktops) 1 12-16-2013 08:12 PM
Kenmore Elite baking element not heating candagrm Oven Repair (including Ranges and Cooktops) 1 12-16-2013 02:19 AM
Kenmore elite heating element 95wagon Dishwasher Repair 0 09-06-2010 01:12 AM
Kenmore Elite microwave, not heating ccall Microwave Repair 1 05-14-2010 12:07 PM
Kenmore Elite not heating Hoff Dryer Repair 2 01-13-2010 01:52 PM
