Discuss
lg tromm electric dryer blowing thermostat
 in
Dryer Repair
I have a LG Tromm dryer (electric) that quit heating a few weeks ago. I found that the hi-limit thermostat
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » lg tromm electric dryer blowing thermostat
  #1 (permalink)
Old 02-06-2014, 05:18 PM
Junior Member
newhouse is on a distinguished road
Default lg tromm electric dryer blowing thermostat
Model Number: dle5977   Brand: -other-   Age: 1 - 5 years
I have a LG Tromm dryer (electric) that quit heating a few weeks ago. I found that the hi-limit thermostat was no good (no continuity). I installed a new one and it produced heat for around 30 minutes and quit heating. I took it apart and the thermostat was blown again. I put another new stat in and the same thing happened again, 30 min. of heat then blows stat. I checked the heating coils and they are not shorted to ground. I also installed new ductwork to the outside before the last blown stat. Any ideas where to look next?
Related Models
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
General Electric DLL3280SBLWH Gas dryer
General Electric DLL3480SBLAD Gas dryer
General Electric DLL3480SBLWH Gas dryer
General Electric DLL3680SBLAD Gas dryer
General Electric DLL3680SBLWH Gas dryer
  #2 (permalink)
Old 02-12-2014, 08:26 AM
Junior Member
Default in addition
I did some more checking; there are no obstructions in the air circulation system. The other two thermostats measure zero ohms resistance and the thermistor measures infinite ohms. All seals appear tight. I do not see any broken coils in heating element. The measurements for the heating coil are; Red to blue-18 ohms, red to yellow- 18 ohms, yellow to blue- 26 ohms. None of the leads have continuity to ground. It is 60 degrees in basement. Thank you for any help.
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Dryer keeps blowing thermostat dfrye Dryer Repair 2 11-28-2013 04:32 AM
Roper dryer keeps blowing high limit thermostat Sparty1721 Dryer Repair 5 11-17-2013 06:18 PM
KitchenAid Superba Electric Dryer - Keeps blowing fuse dennisloyola Dryer Repair 0 08-02-2013 05:07 AM
Amana Dryer Blowing Motor Thermostat horrocks Dryer Repair 3 07-20-2012 02:48 AM
Dryer keeps blowing electric panel fuse birdman Dryer Repair 8 11-23-2008 12:36 PM
