Discuss
Whirlpool Duet F01 error
 in
Dryer Repair
Have a Whirlpool Duet dryer that will dry, but not completely. In reviewing the diagnostic manual and testing the thermal
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Duet F01 error
  #1 (permalink)
Old 02-06-2014, 02:54 PM
Junior Member
tpburt is on a distinguished road
Default Whirlpool Duet F01 error
Model Number: WGD9750WW1   Brand: Whirlpool   Age: 1 - 5 years
Have a Whirlpool Duet dryer that will dry, but not completely. In reviewing the diagnostic manual and testing the thermal fuse, I thought that was my problem and went ahead and replaced it. The dryer does light and heat but does not get real hot. I then ran the diagnostic procedure which is returning a F01 error indicating the Electronics Control board is bad. (Part number W10256719) I don't have any problem replacing that board since it is fairly easy to get to, however, how reliable is the system diagnostics? Is this F01 often a false positive that is masking the real problem?
Related Models
Whirlpool WGD9750WW1 27" GAS DRYER
Whirlpool WGD97HEXL0 GAS DRYER
Whirlpool WGD97HEXL1 27" GAS DRYER
Whirlpool WGD97HEXL2 27" GAS DRYER
Whirlpool WGD97HEXR0 GAS DRYER
Whirlpool WGD97HEXR1 27" GAS DRYER
Whirlpool WGD97HEXR2 27" GAS DRYER
Whirlpool WGD97HEXW0 GAS DRYER
Whirlpool WGD97HEXW1 27" GAS DRYER
Whirlpool WGD97HEXW2 27" GAS DRYER
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"Electric Range Coil Cooktop E-Z Clean Oven
Whirlpool WGE33001 30" Electric Range E-Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E-Z Clean Oven
Whirlpool WGE34304 30" Electric Range E-Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
White Westinghouse WGF317ESB White Westinghouse/range
White Westinghouse WGF317ESC White Westinghouse/range
Frigidaire WGF321WADA Wwh(v1) / Gas Range
Frigidaire WGF321WADB Wwh(v1) / Gas Range
Frigidaire WGF321WAWA Wwh(v2) / Gas Range
Frigidaire WGF321WAWB Wwh(v2) / Gas Range
Frigidaire WGF323BADA Wwh(v3) / Gas Range
Frigidaire WGF323BADB Wwh(v1) / Gas Range
Frigidaire WGF323BADC Wwh(v1) / Gas Range
Frigidaire WGF323BADD Wwh(v1) / Gas Range
Frigidaire WGF323BADE Wwh(v1) / Gas Range
Frigidaire WGF323BAWA Wwh(v4) / Gas Range
Frigidaire WGF323BAWB Wwh(v2) / Gas Range
Frigidaire WGF323BAWC Wwh(v2) / Gas Range
Frigidaire WGF323BAWD Wwh(v2) / Gas Range
Frigidaire WGF323BAWE Wwh(v2) / Gas Range
Frigidaire WGF324BBDB Wwh(v0) / Gas Range
Frigidaire WGF324BBDC Wwh(v1) / Gas Range
Frigidaire WGF324BBWB Wwh(v0) / Gas Range
Frigidaire WGF324BBWC Wwh(v2) / Gas Range
Frigidaire WGF325BADA Wwh(v5) / Gas Range
Frigidaire WGF325BADB Wwh(v1) / Gas Range
Frigidaire WGF325BADC Wwh(v1) / Gas Range
Frigidaire WGF325BADD Wwh(v1) / Gas Range
Frigidaire WGF325BAWA Wwh(v6) / Gas Range
Frigidaire WGF325BAWB Wwh(v2) / Gas Range
Frigidaire WGF325BAWC Wwh(v2) / Gas Range
Frigidaire WGF325BAWD Wwh(v2) / Gas Range
Frigidaire WGF337BBDA Wwh(v1) / Gas Range
Frigidaire WGF337BBDB Wwh(v1) / Gas Range
Frigidaire WGF337BBDC Wwh(v1) / Gas Range
Frigidaire WGF337BBWA Wwh(v2) / Gas Range
Frigidaire WGF337BBWB Wwh(v2) / Gas Range
Frigidaire WGF337BBWC Wwh(v2) / Gas Range
Frigidaire WGF337CBSA Wwh(v3) / Gas Range
Frigidaire WGF337CBSB Wwh(v3) / Gas Range
Frigidaire WGF337CBSC Wwh(v3) / Gas Range
White Westinghouse WGF350ESA White Westinghouse/range
White Westinghouse WGF350ESB White Westinghouse/range
White Westinghouse WGF350ESC White Westinghouse/range
White Westinghouse WGF350ESE White Westinghouse/range
Frigidaire WGF350SADA Wwh(v1) / Gas Range
Frigidaire WGF350SADB Wwh(v2) / Gas Range
Frigidaire WGF350SADD Wwh(v1) / Gas Range
Frigidaire WGF350SADE Wwh(v1) / Gas Range
Frigidaire WGF350SAWA Wwh(v3) / Gas Range
Frigidaire WGF350SAWB Wwh(v4) / Gas Range
Frigidaire WGF350SAWD Wwh(v2) / Gas Range
Frigidaire WGF350SAWE Wwh(v2) / Gas Range
White Westinghouse WGF351ESA White Westinghouse/range
White Westinghouse WGF351ESB White Westinghouse/range
White Westinghouse WGF351ESC White Westinghouse/range
Frigidaire WGF353BADA Wwh(v1) / Gas Range
Frigidaire WGF353BADB Wwh(v2) / Gas Range
Frigidaire WGF353BADE Wwh(v3) / Gas Range
Frigidaire WGF353BAWA Wwh(v3) / Gas Range
Frigidaire WGF353BAWB Wwh(v4) / Gas Range
Frigidaire WGF353BAWE Wwh(v4) / Gas Range
Frigidaire WGF353CASA Wwh(v5) / Gas Range
Frigidaire WGF353CASB Wwh(v6) / Gas Range
Frigidaire WGF353CASC Wwh(v0) / Gas Range
White Westinghouse WGF354BJDA White Westinghouse/gas Range
White Westinghouse WGF354BJWA White Westinghouse/gas Range
Frigidaire WGF355BADA Wwh(v1) / Gas Range
Frigidaire WGF355BADB Wwh(v2) / Gas Range
Frigidaire WGF355BADC Wwh(v1) / Gas Range
Frigidaire WGF355BADD Wwh(v2) / Gas Range
Frigidaire WGF355BADE Wwh(v1) / Gas Range
Frigidaire WGF355BADF Wwh(v1) / Gas Range
Frigidaire WGF355BAWA Wwh(v3) / Gas Range
Frigidaire WGF355BAWB Wwh(v4) / Gas Range
Frigidaire WGF355BAWC Wwh(v3) / Gas Range
Frigidaire WGF355BAWD Wwh(v4) / Gas Range
Frigidaire WGF355BAWE Wwh(v2) / Gas Range
Frigidaire WGF355BAWF Wwh(v2) / Gas Range
Frigidaire WGF357CBSB Wwh(v0) / Gas Range
Frigidaire WGF357CBSC Wwh(v0) / Gas Range
Whirlpool WGP30802 30" Electric Range Coil Cooktop
Whirlpool WGP32801 30" Electric Range Self Clean Oven
Whirlpool WGP34804 30" Electric Range Self Clean Oven
Whirlpool WGP34805 30" Electric Range Self Clean Oven
Whirlpool WGP34904 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Whirlpool WGP34905 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
White Westinghouse WGQ332HS1 GAS DRYER
White Westinghouse WGR211ES0 White Westinghouse/dryer
White Westinghouse WGR211ES1 DRYER
White Westinghouse WGR211ES2 DRYER
White Westinghouse WGR242AQ2 White Westinghouse/gas Dryer
White Westinghouse WGR242AQ3 White Westinghouse/gas Dryer
White Westinghouse WGR242AS2 White Westinghouse/gas Dryer
White Westinghouse WGR242AS3 White Westinghouse/gas Dryer
White Westinghouse WGR242AS4 White Westinghouse/dryer
White Westinghouse WGR242AS5 White Westinghouse/dryer
Whirlpool WGT3300SQ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool WGT3300SQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool WGT3300SQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool WGT3300XQ0 LAUNDRY SYSTEM
General Electric WHDRE526E1WW Washer
General Electric WHDRE526E6WW Washer
General Electric WHDRR418E1WW Washer
General Electric WHDRR418E3WW Washer
General Electric WHDRR418E4WW Washer
General Electric WHDRR418E5WW Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool duet error F3 E2 Charlie2210 Washer Repair 6 04-07-2018 12:38 PM
WhirlPool Duet Fo1 Error wellerons Dryer Repair 3 06-14-2015 05:46 AM
Whirlpool Duet F22 Error pahey Washer Repair 0 01-12-2014 06:38 PM
Whirlpool Duet FH error rwazbill Washer Repair 0 05-09-2012 11:33 AM
Whirlpool duet F11 error kheda61 Washer Repair 1 06-09-2009 05:31 PM
