Discuss
Dryer cycle won't start
 in
Dryer Repair
Dryer ran perfectly, put in a new load. Turned knob to select cycle and hit start button. Nothing. It sounds
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer cycle won't start
  #1 (permalink)
Old 02-06-2014, 02:31 PM
Junior Member
Dennis H is on a distinguished road
Default Dryer cycle won't start
Model Number: LGN2000PWO   Brand: Whirlpool   Age: 5 - 10 years
Dryer ran perfectly, put in a new load. Turned knob to select cycle and hit start button. Nothing. It sounds like the timer ticking. I turned the knob to different cycles. Just ticking noise. I held a little tension on the knob to select cycle. It ran for a couple minutes while I held tension on the knob. As soon as I let go it stopped running and will not run again.
Related Models
Whirlpool LGN3434AW0 Residential Dryer
Whirlpool LGN3624BN0 GAS DRYER
Whirlpool LGN3624BN1 GAS DRYER
Whirlpool LGN3624BN2 GAS DRYER
Whirlpool LGN3624BW0 GAS DRYER
Whirlpool LGN3624BW1 GAS DRYER
Whirlpool LGN3624BW2 GAS DRYER
Whirlpool LGN3634DW0 GAS DRYER
Whirlpool LGN3634DW1 GAS DRYER
Whirlpool LGP6646AN1 GAS DRYER
Whirlpool LGP6646AN2 GAS DRYER
Whirlpool LGP6646AW0 Residential Dryer
Whirlpool LGP6646AW1 GAS DRYER
Whirlpool LGP6646AW2 GAS DRYER
Whirlpool LGP6848AN1 GAS DRYER
Whirlpool LGP6848AW0 Residential Dryer
Whirlpool LGP6848AW1 GAS DRYER
Whirlpool LGP7858AN2 GAS DRYER
Whirlpool LGP7858AQ2 GAS DRYER
Whirlpool LGP7858AW0 Residential Dryer
Whirlpool LGP7858AW2 GAS DRYER
Whirlpool LGP7858AZ2 GAS DRYER
Frigidaire LGQ1442ES0 Frigidaire/dryer
Frigidaire LGQ1442ES1 DRYER
Frigidaire LGQ1442ES2 DRYER
Frigidaire LGQ1452KS0 DRYER
Frigidaire LGQ2152EE0 Frigidaire/dryer
Frigidaire LGQ2152EE1 DRYER
Frigidaire LGQ2152EE2 DRYER
Frigidaire LGQ2152EE3 DRYER
Frigidaire LGQ2152ES0 Frigidaire/dryer
Frigidaire LGQ2152HS0 DRYER
Frigidaire LGQ2152HS1 DRYER
Frigidaire LGQ332DS0 Frigidaire/dryer
Frigidaire LGQ6000ES0 Frigidaire/dryer
Frigidaire LGQ6000ES1 Frigidaire/dryer
Frigidaire LGQ6000ES2 Frigidaire/dryer
Frigidaire LGQ6400FS0 DRYER
Frigidaire LGQ6400FS1 DRYER
Frigidaire LGQ642DS0 Frigidaire/dryer
Frigidaire LGQ7000EG0 Frigidaire/dryer
Frigidaire LGQ7000ES0 Frigidaire/dryer
Frigidaire LGQ7000ES1 Frigidaire/dryer
Frigidaire LGQ7000ES2 Frigidaire/dryer
Whirlpool LGQ7030KQ0 DRYER
Whirlpool LGQ7030KQ1 DRYER
Whirlpool LGQ7030KQ2 29"GAS DRYER
Frigidaire LGQ8000FE0 DRYER
Whirlpool LGQ8000HQ0 DRYER
Whirlpool LGQ8000HQ1 GAS DRYER
Whirlpool LGQ8000JQ0 GAS DRYER
Whirlpool LGQ8000JQ1 GAS DRYER
Whirlpool LGQ8000JQ2 GAS DRYER
Whirlpool LGQ8000JQ3 DRYER
Whirlpool LGQ8000JQ4 29"GAS DRYER
Whirlpool LGQ8000JQ5 29"GAS DRYER
Whirlpool LGQ8100KQ0 RESIDENTIAL DRYER
Whirlpool LGQ8100KQ1 RESIDENTIAL DRYER
Whirlpool LGQ8100KT0 RESIDENTIAL DRYER
Whirlpool LGQ8100KT1 RESIDENTIAL DRYER
Whirlpool LGQ8611LG0 RESIDENTIAL DRYER
Whirlpool LGQ8611LG1 27"GAS DRYER
Whirlpool LGQ8611LW0 RESIDENTIAL DRYER
Whirlpool LGQ8611LW1 27"GAS DRYER
Whirlpool LGQ8611PG0 27"GAS DRYER
Whirlpool LGQ8611PG1 27"GAS DRYER
Whirlpool LGQ8611PG2 27"GAS DRYER
Whirlpool LGQ8611PG3 27"GAS DRYER
Whirlpool LGQ8611PW0 27"GAS DRYER
Whirlpool LGQ8611PW1 27"GAS DRYER
Whirlpool LGQ8611PW2 27"GAS DRYER
Whirlpool LGQ8611PW3 27"GAS DRYER
Whirlpool LGQ8621PG0 27" GAS DRYER
Whirlpool LGQ8621PG1 27" GAS DRYER
Whirlpool LGQ8621PG2 27" GAS DRYER
Whirlpool LGQ8621PG3 27" GAS DRYER
Whirlpool LGQ8621PW0 27" GAS DRYER
Whirlpool LGQ8621PW1 27" GAS DRYER
Whirlpool LGQ8621PW2 27" GAS DRYER
Whirlpool LGQ8621PW3 27" GAS DRYER
Whirlpool LGQ8800JQ0 GAS DRYER
Whirlpool LGQ8800JQ1 DRYER
Whirlpool LGQ8800JQ2 DRYER
Whirlpool LGQ8800JT0 GAS DRYER
Whirlpool LGQ8800JT1 DRYER
Whirlpool LGQ8800JT2 DRYER
Whirlpool LGQ8857HQ0 DRYER
Whirlpool LGQ8857HQ1 GAS DRYER
Whirlpool LGQ8857HZ0 DRYER
Whirlpool LGQ8857HZ1 GAS DRYER
Whirlpool LGQ8857JQ0 GAS DRYER
Whirlpool LGQ8857JQ1 DRYER
Whirlpool LGQ8857JQ2 DRYER
Whirlpool LGQ8857JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8857JT0 GAS DRYER
Whirlpool LGQ8857JT1 DRYER
Whirlpool LGQ8857JT2 DRYER
Whirlpool LGQ8857JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858HQ0 GAS DRYER
Whirlpool LGQ8858HQ1 GAS DRYER
Whirlpool LGQ8858HZ0 GAS DRYER
Whirlpool LGQ8858HZ1 GAS DRYER
Whirlpool LGQ8858JQ0 GAS DRYER
Whirlpool LGQ8858JQ1 DRYER
Whirlpool LGQ8858JQ2 DRYER
Whirlpool LGQ8858JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8858JT0 GAS DRYER
Whirlpool LGQ8858JT1 DRYER
Whirlpool LGQ8858JT2 DRYER
Whirlpool LGQ8858JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858JZ0 GAS DRYER
Whirlpool LGQ8858JZ1 DRYER
Whirlpool LGQ8858JZ2 DRYER
Whirlpool LGQ9030PQ0 29"GAS DRYER
Whirlpool LGQ9030PQ1 29"GAS DRYER
Whirlpool LGQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9508KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9508LG0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW1 29"GAS DRYER
  #2 (permalink)
Old 02-06-2014, 04:33 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Unplug dryer, open control panel and check connections on back of timer. Make sure they are clean and tight. If no problem found there, replace timer.
Whirlpool 3406725 Timer - AppliancePartsPros.com
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gas Dryer Won't Start Cycle dietrichnp1 Dryer Repair 2 08-05-2013 06:17 PM
Dryer Won't Start After 1 Cycle. jysylvia Dryer Repair 2 05-08-2012 10:32 AM
Gas Dryer Goes Into Finish Cycle at Start mike1 Dryer Repair 0 08-20-2009 02:14 PM
Dryer only heats at start of cycle kdhb1@msn.com Dryer Repair 5 04-09-2009 02:22 PM
Dryer Won't Start After Initial Cycle 1965bubba Dryer Repair 1 12-18-2007 05:06 AM
