Discuss
Frigidair affinity gas dryer error E56 032
 in
Dryer Repair
My affinity gas dryer has suddenly stopped drying, runs but no heat. Sometimes it stops with the three lights above
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidair affinity gas dryer error E56 032
  #1 (permalink)
Old 02-05-2014, 05:29 AM
Junior Member
Mholdeman is on a distinguished road
Default Frigidair affinity gas dryer error E56 032
Model Number: LGQ600ES2   Brand: Frigidaire   Age: 5 - 10 years
My affinity gas dryer has suddenly stopped drying, runs but no heat. Sometimes it stops with the three lights above start flashing and err in LCD.
Following posts here got the error code.
Revision is 06
Error code is
E56 032
Any help is appreciated.
Mike
Related Models
Frigidaire LGQ6400FS0 DRYER
Frigidaire LGQ6400FS1 DRYER
Frigidaire LGQ642DS0 Frigidaire/dryer
Frigidaire LGQ7000EG0 Frigidaire/dryer
Frigidaire LGQ7000ES0 Frigidaire/dryer
Frigidaire LGQ7000ES1 Frigidaire/dryer
Frigidaire LGQ7000ES2 Frigidaire/dryer
Whirlpool LGQ7030KQ0 DRYER
Whirlpool LGQ7030KQ1 DRYER
Whirlpool LGQ7030KQ2 29"GAS DRYER
Frigidaire LGQ8000FE0 DRYER
Whirlpool LGQ8000HQ0 DRYER
Whirlpool LGQ8000HQ1 GAS DRYER
Whirlpool LGQ8000JQ0 GAS DRYER
Whirlpool LGQ8000JQ1 GAS DRYER
Whirlpool LGQ8000JQ2 GAS DRYER
Whirlpool LGQ8000JQ3 DRYER
Whirlpool LGQ8000JQ4 29"GAS DRYER
Whirlpool LGQ8000JQ5 29"GAS DRYER
Whirlpool LGQ8100KQ0 RESIDENTIAL DRYER
Whirlpool LGQ8100KQ1 RESIDENTIAL DRYER
Whirlpool LGQ8100KT0 RESIDENTIAL DRYER
Whirlpool LGQ8100KT1 RESIDENTIAL DRYER
Whirlpool LGQ8611LG0 RESIDENTIAL DRYER
Whirlpool LGQ8611LG1 27"GAS DRYER
Whirlpool LGQ8611LW0 RESIDENTIAL DRYER
Whirlpool LGQ8611LW1 27"GAS DRYER
Whirlpool LGQ8611PG0 27"GAS DRYER
Whirlpool LGQ8611PG1 27"GAS DRYER
Whirlpool LGQ8611PG2 27"GAS DRYER
Whirlpool LGQ8611PG3 27"GAS DRYER
Whirlpool LGQ8611PW0 27"GAS DRYER
Whirlpool LGQ8611PW1 27"GAS DRYER
Whirlpool LGQ8611PW2 27"GAS DRYER
Whirlpool LGQ8611PW3 27"GAS DRYER
Whirlpool LGQ8621PG0 27" GAS DRYER
Whirlpool LGQ8621PG1 27" GAS DRYER
Whirlpool LGQ8621PG2 27" GAS DRYER
Whirlpool LGQ8621PG3 27" GAS DRYER
Whirlpool LGQ8621PW0 27" GAS DRYER
Whirlpool LGQ8621PW1 27" GAS DRYER
Whirlpool LGQ8621PW2 27" GAS DRYER
Whirlpool LGQ8621PW3 27" GAS DRYER
Whirlpool LGQ8800JQ0 GAS DRYER
Whirlpool LGQ8800JQ1 DRYER
Whirlpool LGQ8800JQ2 DRYER
Whirlpool LGQ8800JT0 GAS DRYER
Whirlpool LGQ8800JT1 DRYER
Whirlpool LGQ8800JT2 DRYER
Whirlpool LGQ8857HQ0 DRYER
Whirlpool LGQ8857HQ1 GAS DRYER
Whirlpool LGQ8857HZ0 DRYER
Whirlpool LGQ8857HZ1 GAS DRYER
Whirlpool LGQ8857JQ0 GAS DRYER
Whirlpool LGQ8857JQ1 DRYER
Whirlpool LGQ8857JQ2 DRYER
Whirlpool LGQ8857JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8857JT0 GAS DRYER
Whirlpool LGQ8857JT1 DRYER
Whirlpool LGQ8857JT2 DRYER
Whirlpool LGQ8857JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858HQ0 GAS DRYER
Whirlpool LGQ8858HQ1 GAS DRYER
Whirlpool LGQ8858HZ0 GAS DRYER
Whirlpool LGQ8858HZ1 GAS DRYER
Whirlpool LGQ8858JQ0 GAS DRYER
Whirlpool LGQ8858JQ1 DRYER
Whirlpool LGQ8858JQ2 DRYER
Whirlpool LGQ8858JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8858JT0 GAS DRYER
Whirlpool LGQ8858JT1 DRYER
Whirlpool LGQ8858JT2 DRYER
Whirlpool LGQ8858JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858JZ0 GAS DRYER
Whirlpool LGQ8858JZ1 DRYER
Whirlpool LGQ8858JZ2 DRYER
Whirlpool LGQ9030PQ0 29"GAS DRYER
Whirlpool LGQ9030PQ1 29"GAS DRYER
Whirlpool LGQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9508KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9508LG0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW1 29"GAS DRYER
Whirlpool LGQ9508PG0 29"GAS DRYER
Whirlpool LGQ9508PG1 29"GAS DRYER
Whirlpool LGQ9508PW0 29"GAS DRYER
Whirlpool LGQ9508PW1 29"GAS DRYER
Whirlpool LGQ9557KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9557KT0 RESIDENTIAL DRYER
Whirlpool LGQ9557KT1 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9558KT0 RESIDENTIAL DRYER
Whirlpool LGQ9558KT1 RESIDENTIAL DRYER
Whirlpool LGQ9857LG0 RESIDENTIAL DRYER
Whirlpool LGQ9857LG1 29"GAS DRYER
Whirlpool LGQ9857LW0 RESIDENTIAL DRYER
Whirlpool LGQ9857LW1 29"GAS DRYER
Whirlpool LGQ9857PW0 29"GAS DRYER
Whirlpool LGQ9858LG0 RESIDENTIAL DRYER
Whirlpool LGQ9858LG1 29"GAS DRYER
Whirlpool LGQ9858LW0 RESIDENTIAL DRYER
Whirlpool LGQ9858LW1 29"GAS DRYER
Whirlpool LGQ9858PG0 29"GAS DRYER
Whirlpool LGQ9858PG1 29"GAS DRYER
Whirlpool LGQ9858PW0 29"GAS DRYER
Whirlpool LGQ9858PW1 29"GAS DRYER
Whirlpool LGR2614BW0 GAS DRYER
Whirlpool LGR2614BW1 GAS DRYER
Whirlpool LGR2614BW2 GAS DRYER
Whirlpool LGR2614DW0 GAS DRYER
Whirlpool LGR2614DW1 GAS DRYER
Whirlpool LGR2614EW0 GAS DRYER
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB RANGE- S/C F/S GAS
Admiral LGR3330ADW RANGE- S/C F/S GAS
Admiral LGR3330ADZ RANGE- S/C F/S GAS
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0 Residential Dryer
  #2 (permalink)
Old 02-05-2014, 07:33 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
I do not see an error E56 on the tech sheet. There is an error E5B which is heater fault. Set timer to normal cycle and temp to high heat, press start and check voltage across control board relay RL2 (leave wires connected). If you read 120vac, then the board is bad. If you read zero, you need to troubleshoot the heater circuit components.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidare Affinity Dryer E68 error code rickh60 Dryer Repair 31 06-02-2016 03:21 PM
Frigidaire Affinity dryer error code E61 napclan6 Dryer Repair 4 02-12-2012 07:23 PM
Frigidaire Affinity Dryer AEQB7000ES0 Error Code E56 dignan Dryer Repair 1 02-03-2012 06:47 PM
Error Code E04 on Frigidaire Affinity Dryer Soarer Dryer Repair 3 02-23-2011 06:18 AM
Frigidaire Affinity dryer error code E9E jpalazzi Dryer Repair 4 04-24-2010 03:20 PM
